timing only at 14 deg.?
Old Apr 19, 2008 | 10:37 AM
92egSnatch's Avatar
Default timing only at 14 deg.?
well ive had a fuel problem as some of you might have read in my other thread
but i went to set the timming today and with the dizzy advanced all the way its only at 14 deg what should i do or how can i fix this to get it to 16 deg
someone please help
Old Apr 19, 2008 | 10:41 AM
yoffer's Avatar
Banned
WHen i did mine, i had it advance all the way and it was only hitting 16* so it wasnt a big deal, but i slotted the distributor in case i ever had to advance it more in the future.
Old Apr 19, 2008 | 11:47 AM
92egSnatch's Avatar
Default Re: (yoffer)
how could i do that?
Old Apr 20, 2008 | 07:47 AM
92egSnatch's Avatar
Default Re: (92egSnatch)
bump anyone got any ideas why my timing will only go up to 14*
Old Apr 20, 2008 | 08:02 AM
geebs's Avatar
Timing belt not timed correctly?
Old Apr 20, 2008 | 11:06 AM
92egSnatch's Avatar
Default Re: (geebs)
it looked like it was spot on when it was at tdc the timing marks on the cam gear were where they needed to be but i didnt check the crank
any other ideas?
Old Apr 20, 2008 | 05:30 PM
jdong's Avatar
whats wrong with that? Thats good 16+ -. its good to have 14 or 18
Old Apr 20, 2008 | 06:11 PM
el_toro_de_magnifico's Avatar
Default Re: (jdong)
have the timing belt re-installed. this happend to me also and we just reinstalled the tbel.
you could reslot the dizzy by makin the holes longer for the dizzy to move further but i wouldnt suggest it.
Old Apr 20, 2008 | 07:06 PM
92egSnatch's Avatar
Default Re: (el_toro_de_magnifico)
well ill reinstall the tbelt and see if that helps guess i need to go buy a haynes for my car or if some one could show me a pic of where to line up the crank i know how to line up the cam gear cause its exactly the same as my em2
LoneAutosport
Oct 7, 2009 07:17 AM
NatedoggAZ
14
Apr 13, 2005 09:51 AM
Hybridize
Oct 31, 2003 11:31 AM
Jamison
May 21, 2002 05:58 AM
