MPG 13 WTH does the CRV get 13MPG?
Old Apr 19, 2008 | 09:02 AM
Dead CIVIC's Avatar
Veteran: Army
Default MPG 13 WTH does the CRV get 13MPG?
why is my car getting 13 miles per gallon with a 00' b20? I't all stock. and I dont be redlining all the time.
i have a b16 tranny.
ls ECU
i really need some help this si getting stupid with gas prices so high.
i have to PCH from el monte everyday and back. does everyone else this [freak]ed up mileage.?
Old Apr 19, 2008 | 09:53 AM
pdiggitydogg's Avatar
The b16 tranny isnt helping you out any, but that is extremely excessive fuel consumption.
If your exhaust is black, you may be burning a lot of fuel - perhaps an injector is stuck open?
Ever cleaned them? Run a test to see if they close?
Poor Ign timing would also burn a little more fuel, but certainly not that much....
Old Apr 19, 2008 | 11:26 AM
Dead CIVIC's Avatar
Veteran: Army
Default Re: (pdiggitydogg)
cool i knew something was wrong.
any other ideas on things to chech?
Old Apr 20, 2008 | 09:04 AM
Dead CIVIC's Avatar
Veteran: Army
Default Re: MPG 13 WTH does the CRV get 13MPG? (Dead CIVIC)
Old Apr 20, 2008 | 09:42 AM
Dasfinc's Avatar
Yea, I agree with the above, B16 trans will Kill mileage in a B20.
Did you replace the O2, Plugs/wires/cap/rotor when you installed the motor?
Old Apr 21, 2008 | 12:17 PM
Dead CIVIC's Avatar
Veteran: Army
Default Re: MPG 13 WTH does the CRV get 13MPG? (Dasfinc)
negative...but i want to add that at 3k and before 4.2K rpm it sputters allot and it is nasty the car jumps cause of the sputter and if i give it more gas it just makes a gurgle sound and eventually move acordingly to the gas that is being given?
Old Apr 21, 2008 | 12:19 PM
EG2Driver's Avatar
get the right ECU, make sure the tune-up is fresh and maybe look at oxygen sensors? When they go bad, they don't always throw a CEL, but they do destroy MPG.
Old Apr 21, 2008 | 12:34 PM
Dead CIVIC's Avatar
Veteran: Army
Default Re: MPG 13 WTH does the CRV get 13MPG? (EG2Driver)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG2Driver &raquo;</TD></TR><TR><TD CLASS="quote">get the right ECU, make sure the tune-up is fresh and maybe look at oxygen sensors? When they go bad, they don't always throw a CEL, but they do destroy MPG.</TD></TR></TABLE>
what ECu should i be using?
Old Apr 21, 2008 | 01:22 PM
EG2Driver's Avatar
you should be running the ECU that originally was made for the engine that is currently in the car. LS is a 1.8l and you are driving a B20. There are differences between the two, no?
Old Apr 21, 2008 | 01:25 PM
That ecu is fine... Its the same engine, just 84mm bore instead of 81. Its not chipped with some silly "mugen" or "spoon" program, right?
I'll agree that the o2 needs to be changed. Get a Denso from http://www.sparkplugs.com. Denso or NGK...nothing else.
Check the TPS with a multimeter, as per my instructions on another thread (search for it)
Old Apr 21, 2008 | 01:34 PM
EG2Driver's Avatar
Know what? Pull a plug, take a photo of it and post it. It'll tell a whole lot about how the engine is running. Do that and get back to us!
Old Apr 22, 2008 | 07:14 AM
Dead CIVIC's Avatar
Veteran: Army
Default Re: (EG2Driver)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG2Driver &raquo;</TD></TR><TR><TD CLASS="quote">Know what? Pull a plug, take a photo of it and post it. It'll tell a whole lot about how the engine is running. Do that and get back to us!</TD></TR></TABLE>
cool I'll do that first.
Old Apr 22, 2008 | 07:50 AM
I dont know if thats going to do any good. We already know its running rich as hell (that is, unless you have a fuel leak)
justaquestion
53
Jan 17, 2016 06:39 PM
switchfoot_84
Jul 12, 2007 09:37 PM
crxpwr1
10
Apr 13, 2007 07:55 AM
geces23
Jun 27, 2006 04:09 PM
eXcelonTypeR
Aug 30, 2005 08:40 AM
