*** Recent cage work in SOCAL***
Old Apr 19, 2008 | 08:21 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default *** Recent cage work in SOCAL***
big thanx to Dillan Chassis for the work. and i highly recommend him for work here in SOCAL
dropping the car off at the shop
main hoop in
working the step plate for the main hoop
bending the front half hoops
main hoop is tucked away nice and tight
top half
D bars
rear legs
door bars
harness tas and seat brace
again if you are looking for work on your car in socal go see Dillan Chassis in SOCAL (310)266-6455
Old Apr 19, 2008 | 10:12 PM
slammed_93_hatch's Avatar
Default Re: *** Recent cage work in SOCAL*** (S@nt0s)
How does he gett a good bead on the front tubes were they attach too the main hoop?
Or is it not that tight of a fit
Old Apr 20, 2008 | 02:05 AM
Flashmn's Avatar
Default Re: *** Recent cage work in SOCAL*** (slammed_93_hatch)
those floorboards look like they could use some TLC...
Old Apr 20, 2008 | 07:35 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slammed_93_hatch &raquo;</TD></TR><TR><TD CLASS="quote">How does he gett a good bead on the front tubes were they attach too the main hoop?
Or is it not that tight of a fit</TD></TR></TABLE>
its a snug fit but theres room to get the bead wrapped around
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flashmn &raquo;</TD></TR><TR><TD CLASS="quote">those floorboards look like they could use some TLC... </TD></TR></TABLE>
they will get their time... hard to work with 30+ year old paper thin metal.
Old Apr 20, 2008 | 02:52 PM
Fabman's Avatar
Lierley Fab
pic #11 looks like the tube has a big dent then it looks like he welded it up ... cool car
Old Apr 20, 2008 | 05:26 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: *** Recent cage work in SOCAL*** (Fabman)
you talking about the driverside by the floorpan?
thats a ben to give a added inch to get in and out for me.
Old Apr 21, 2008 | 01:10 PM
Fabman's Avatar
Lierley Fab
no the upper tube that mounts to the main cage
Old Apr 22, 2008 | 07:28 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fabman &raquo;</TD></TR><TR><TD CLASS="quote">no the upper tube that mounts to the main cage</TD></TR></TABLE>
nope i assure you there are no coverups on this cage.
Old Apr 22, 2008 | 08:47 PM
Fabman's Avatar
Lierley Fab
Old Apr 23, 2008 | 12:47 AM
140sx's Avatar
drag 510? sick
what engine is in it.
Old Apr 23, 2008 | 07:50 AM
spiceisler's Avatar
Default Re: (140sx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 140sx &raquo;</TD></TR><TR><TD CLASS="quote">drag 510? sick
what engine is in it.</TD></TR></TABLE>
FIY ........it's not a 510! It's a 1200.
Old Apr 23, 2008 | 10:25 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: (140sx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spiceisler &raquo;</TD></TR><TR><TD CLASS="quote">
FIY ........it's not a 510! It's a 1200.</TD></TR></TABLE>
yuppers
running a CA18DET
Old Apr 23, 2008 | 10:36 AM
ickyhonda's Avatar
Default Re: (S@nt0s)
what tube bender is that?
Modified by ickyhonda at 1:58 PM 4/23/2008
Old Apr 23, 2008 | 11:17 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: (ickyhonda)
i couldnt tell you boss, ill ask tho
Old Apr 23, 2008 | 11:29 AM
hootiehoo's Avatar
how does the seat bolt to the main hoop?
so you just drill into the fiberglss shell??
i never really got that part....
Old Apr 23, 2008 | 12:13 PM
SMSP's Avatar
You are using exhaust tubing for your roll cage? What sanctioning body allows that? That's a poor way or doing the belt tabs. They should be loaded in tension.
Old Apr 23, 2008 | 01:27 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: *** Recent cage work in SOCAL*** (SMSP)
no it isnt exhaust tubing it is i believe .120 wall tickness or whatever the min is for mild stell and will be NHRA certified.
whats wrong with the tabs?
Modified by S@nt0s at 2:50 PM 4/23/2008
Old Apr 23, 2008 | 01:47 PM
splitime's Avatar
Off topic... is the outside paint a roller job?
Old Apr 23, 2008 | 01:51 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: *** Recent cage work in SOCAL*** (splitime)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by splitime &raquo;</TD></TR><TR><TD CLASS="quote">Off topic... is the outside paint a roller job?</TD></TR></TABLE>
doesnt appear to be, previous owner did it. i will be spraying it back to the original color
Old Apr 23, 2008 | 05:19 PM
SMSP's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S@nt0s &raquo;</TD></TR><TR><TD CLASS="quote">no it isnt exhaust tubing it is i believe .120 wall tickness or whatever the min is for mild stell and will be NHRA certified.
Modified by S@nt0s at 2:50 PM 4/23/2008</TD></TR></TABLE>
It may be .120" wall but it is still ERW tubing. If it's allowed in your specs then you are OK. I would just never use it. Roll cages should be DOM or C Moly.
Depending on how the belts would load the tabs in an accident it looks like there would be some bending about the weld.
Old Apr 23, 2008 | 11:28 PM
140sx's Avatar
yuppers
running a CA18DET</TD></TR></TABLE>
Thats hot. why not a sr. ca's are not exactly powerplants + hella hard to find good aftermaket parts.
Yeah i thought it looked a little differant than a 510, wasent 100% sure
Old Apr 24, 2008 | 12:07 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: (140sx)
Yeah i thought it looked a little differant than a 510, wasent 100% sure</TD></TR></TABLE>
cant go wrong with a "BABY RB"
parts arent that hard but arent easy like SR's....
the CA is a cast Iron block and about 50lbs lighter then the SR......
Old Apr 24, 2008 | 06:45 AM
dem0nk1d's Avatar
how you going to take the dash out if you need to get behind it?
Old Apr 24, 2008 | 07:33 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: (dem0nk1d)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dem0nk1d &raquo;</TD></TR><TR><TD CLASS="quote">how you going to take the dash out if you need to get behind it?
there isnt anything under it i need to get into really. old cars like these are really simple .
plus i can just work from under it
Old Apr 26, 2008 | 01:05 PM
JDMCRX's Avatar
Cool any motor shots?
