Gauge Problems..
sry guys i posted this before but im having trouble with both my speedo and tach now. My speedo will be working fine and then randomly bounce around and stop working completely then later it will bounce around some more then pick up with the speed i am at. And after that i started noticing my tach acting up.. one day it just went all the way around and stayed pointing straight down to nothing. ever since then it doesnt seem to work right at all and is either on 0 or just goes straight to 6k then back to 0 when it shifts which is not right when i feel the car shift at what should be 2-3k
Edit: 92 sedan lx auto
Modified by civic08 at 12:15 AM 4/19/2008
When i turn my key to the accessories or on position but dont start it my battery and brake lights come on and stay on i believe but once i start the car they go out and stay out. Is that what you mean or were you referring to while driving they are on
take your dizzy cap off and find the 4 wires that hook onto the ignition module inside the dizzy and make sure that none of them are loose. i was plagued with that problem a couple of times. should be the one of the side of the module. if you have another module try that as well.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RonJ@HT »</TD></TR><TR><TD CLASS="quote">Check whether fuse 12 or 24 is blown in the under-dash fuse box.</TD></TR></TABLE>
#24 looked good but i didnt have a fuse in 12 at all so i took a spare and put it in
fano
May 9, 2011 07:01 AM
Chief Brody
Dec 20, 2004 06:54 AM
