Honda S2000 Honda S2000
Boost gauge w/ CTSC kit (aftercooled)
Old Apr 18, 2008 | 07:43 PM
SuzukaBlueAP2's Avatar
Default Boost gauge w/ CTSC kit (aftercooled)
So I finished my electric boost gauge install. Something just doesn't seem right though. At WOT the most I have seen is 3.7 psi of boost. I've got a 7 psi pulley installed.
I checked, re-checked and checked again all of my vacuum routing for the supercharger kit. Everything is connected as it should be per the Comptech instructions.
I used a vacuum T and shared the vacuum source for my gauge with the FPR. Is this wrong? Should I not be using that? Typically on a previously turbocharged car, I used my waste gate for the source for my gauge.
Am I missing something? Did I possibly get a defective gauge? It is a digital gauge from Summit Racing.
Let me know what you other supercharged guys have done and if you see the full boost pressure and at what rpm.
Old Apr 19, 2008 | 04:01 AM
HondaKyle's Avatar
Default Re: Boost gauge w/ CTSC kit (SuzukaBlueAP2)
do you get full boost right before Vtec? I was in a supercharged one and it get full boost around that area with a 7 pound pulley.
Old Apr 19, 2008 | 04:46 AM
papa5murf's Avatar
Take out the T. Take a picture of how you have setup it and post it. I have mine on the intake manifold.
Old Apr 19, 2008 | 04:50 AM
Default Re: Boost gauge w/ CTSC kit (papa5murf)
Photos coming today!
Old Apr 19, 2008 | 04:51 AM
HondaKyle's Avatar
take some pics of the out side of the car while your at it... I better see pics of the car once i wake up...
Old Apr 19, 2008 | 02:30 PM
Default Re: Boost gauge w/ CTSC kit (HondaKyle)
Just some quick photos...was out at an auto x all day...
yes I know the hood is popped...
new Veilside spoiler. I just set it on for the photo.
engine bay...
will get back to the vacuum lines in just a minute...
Old Apr 19, 2008 | 02:46 PM
ok, let's see if this makes any sense...
in the line going from the top side above the fuel rail down to the vacuum air tank, there is the check valve in there and it has the longer side going down, towards the tank.
Old Apr 19, 2008 | 05:17 PM
papa5murf's Avatar
I have my boost gauge connected to the upper most green line on your picture. It's connected to the little nozzle on the intake manifold.
Old Apr 19, 2008 | 05:34 PM
so the rest of my routing looks correct?
What about the bypass valve? Is is possible mine is not shutting properly and allowing boost to recycle back into the blower instead of getting to my engine?
Old Apr 19, 2008 | 06:05 PM
papa5murf's Avatar
Honestly I'm not too sure, I've never installed a supercharger on the S.
With the turbo I only wire up a couple vacuums hoses. I've eliminated the secondary air pump. ;
Old Apr 19, 2008 | 10:43 PM
ricepicker's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuzukaBlueAP2 &raquo;</TD></TR><TR><TD CLASS="quote">so the rest of my routing looks correct?
What about the bypass valve? Is is possible mine is not shutting properly and allowing boost to recycle back into the blower instead of getting to my engine?</TD></TR></TABLE>
The routing looks correct. I ran a boost guage T'd into the vacuum line to the FPR and it boosted to .5 bar (Around 7 lbs) with my 7lb pulley. That could definitely be a possibility that your bypass valve is not closing all the way. You also might want to check that your belt is tight and not slipping, There could also be a possibility of another boost leak, maybe around the couplers? Or is also could be the guage. If you can try and find a mechanical boost guage from a friend to try out, that also might narrow down your problem. All those are pretty good places to start.
Old Apr 19, 2008 | 11:01 PM
9kFever's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaKyle &raquo;</TD></TR><TR><TD CLASS="quote">do you get full boost right before Vtec? I was in a supercharged one and it get full boost around that area with a 7 pound pulley.</TD></TR></TABLE>
UM, Vortech and Comptech are Centrifical meaning they make peak boost at peak RPM. Its not going to be making full boost right before VTEC
Old Apr 20, 2008 | 03:44 AM
HondaKyle's Avatar
Default Re: Boost gauge w/ CTSC kit (9kFever)
oh well last supercharged s2000 I was in was making 7 pounds right before vtec....
Old Apr 20, 2008 | 08:26 AM
ABCVTEC's Avatar
Then it was running more than 7lbs.
Old Apr 20, 2008 | 10:52 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by papa5murf &raquo;</TD></TR><TR><TD CLASS="quote">Honestly I'm not too sure, I've never installed a supercharger on the S.
With the turbo I only wire up a couple vacuums hoses. I've eliminated the secondary air pump. ;</TD></TR></TABLE>
This was my first supercharger install as well. And same as you, I have turbo install experience from my old Acura. You must have an AEM EMS, no? Otherwise you'd have the silly CEL for the secondary air pump.
Here is my checklist:
1 - remove and reroute vacuum lines according to Comptech install instructions to avoid any possibility of them being incorrect now.
2 - Get a manual boost gauge and T it to the same spot I had the electron one to and compare boost readings.
3 - Try to determine if bypass valve is working correctly. Maybe hook it up to an air compressor?
4 - Ensure all couplers are sealed. (actually already did once)
5 - Check SC belt (again, already did). When I twist the belt at its longest point I can turn it approx. 45-50 degrees max.
6 - Double check electrical connections to electronic boost gauge.
Old Apr 20, 2008 | 11:46 AM
papa5murf's Avatar
I'm running a Hondata Kpro now. There's an option to shut off certain CEL's and the secondary air pump is one of them. I can also shut off all of them if I want.
Assuming all the wiring of the hoses is correct (without the boost gauge). So that is not the issue.
Where do you have the boost gauge connecting to/reading from?
Old Apr 20, 2008 | 12:31 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by papa5murf &raquo;</TD></TR><TR><TD CLASS="quote">Where do you have the boost gauge connecting to/reading from? </TD></TR></TABLE>
It was T'ed in to the same port on my intake manifold that my fuel pressure regulator was connected to.
Old Apr 20, 2008 | 01:06 PM
papa5murf's Avatar
I would suggest trying to eliminate that T connector if at all possible. That is probably the cause of the false readings.
Old Apr 20, 2008 | 01:38 PM
kabaroo's Avatar
borrow another boost gauge from a friend to see if its broken.
Old Apr 20, 2008 | 05:44 PM
ricepicker's Avatar
3 - Try to determine if bypass valve is working correctly. Maybe hook it up to an air compressor?</TD></TR></TABLE>
You could just pull off the elbow from the supercharger to the airbox. At idle you should feel air moving through the bypass valve but instantly shuts when the throttle is opened. I wouldn't know the best way to check and see if it is leaking at say over 3 lbs, though.
Old Apr 22, 2008 | 07:11 PM
Default Re: Boost gauge w/ CTSC kit (ricepicker)
Ok, after much troubleshooting I have been able to determine that my bypass valve is working fine.
I put a mechanical boost gauge in th same spot I T'd the electric one in and was able to see 6-7 psi of boost. So, now I have to figure out if it is the actual gauge or the electronic map sensor/sending unit that is malfunctioning. Time to call Summit tomorrow.
Old Apr 22, 2008 | 08:44 PM
ricepicker's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuzukaBlueAP2 &raquo;</TD></TR><TR><TD CLASS="quote">Ok, after much troubleshooting I have been able to determine that my bypass valve is working fine.
I put a mechanical boost gauge in th same spot I T'd the electric one in and was able to see 6-7 psi of boost. So, now I have to figure out if it is the actual gauge or the electronic map sensor/sending unit that is malfunctioning. Time to call Summit tomorrow.</TD></TR></TABLE>
How is the sending unit wired in? Is it tapped into the MAP signal? If so, I know exactly what your problem is... With the Comptech Kit, remember the ESM that you had to wire in? It's a voltage clamp that hides boost from the ECU. I had an OBDII scanner and looked at the map reading and it was showing 2lbs of boost, I checked with a mechanical boost guage, and it was at 5.5lbs with the stock pulley.
Old Apr 22, 2008 | 10:37 PM
Blownap's Avatar
.............................. right.
Old Apr 22, 2008 | 10:44 PM
9kFever's Avatar
Default Re: Boost gauge w/ CTSC kit (Blownap)
That looks like you got it all setup right. Im tapped into the same line.
Old Apr 23, 2008 | 06:23 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ricepicker &raquo;</TD></TR><TR><TD CLASS="quote">
How is the sending unit wired in? Is it tapped into the MAP signal? If so, I know exactly what your problem is... With the Comptech Kit, remember the ESM that you had to wire in? It's a voltage clamp that hides boost from the ECU. I had an OBDII scanner and looked at the map reading and it was showing 2lbs of boost, I checked with a mechanical boost guage, and it was at 5.5lbs with the stock pulley.</TD></TR></TABLE>
hmm...it's funny you mention that. The gauge and its sending unit don't tap into the OE MAP sensor wiring. I just supply 12v+, a ground, an illumination source and then there is a signal wire on the gauges MAP sensor that goes up to the gauge. The gauges MAP sensor has a nipple on it and still gets a vacuum line run to it.
I did a little test with it though. I blew into the vacuum line going into that sending unit and produced only 0.9 psi on the gauge.
On the mechanical gauge I purchased I did the same thing and produced 2.0 psi.
Getting ready to make a phone call to Summit...
