35/40 vs 40/40 proportion valve
From: fountain inn, sc. where they still rock banjos on porches, usa
hi i was looking on here for some info but couldn"t find it. maybe someone can link me or just answer my question.
as the title says, my question relates to which proportion valve benifit me the most with my setup below. this setup will be in a 90 crx.
90 VW Carrabo front rotors (11" big brake upgrade)
Fastbrake caliper brakets
Axxis brake pads
Stainless Steel brake lines
91 Integra front cailpers
91 Integra rear disc converstion
97 Intgera 1" master cylinder
97 Integra brake booster
thanks
remo
Axxis brake pads
thanks
remo
40/40 should work the best since you have a front and rear disc setup... i believe 35/40 comes off of a front rotor rear drum setup... someone correct me if i'm wrong
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I heart My EF Sedan »</TD></TR><TR><TD CLASS="quote">40/40 should work the best since you have a front and rear disc setup... i believe 35/40 comes off of a front rotor rear drum setup... someone correct me if i'm wrong</TD></TR></TABLE>
I thought the prop valve for the rear drum setup was vastly different.
i knew that the 35/40 came in the SiR. if i'm correct i remember seeing a 35/40 on a Integra thats why i ask. i just wanted to make sure that 40/40 was the best way to go thanks guys for the feedback and reassurance.
