Need Help To Build My F23A4 up
Old Apr 18, 2008 | 05:00 PM
mike0216's Avatar
New User
Default Need Help To Build My F23A4 up
I got a 2000 accord lx with 90k on it. My first plan to swap in a h22 in but i can't afford it right now. so i was thinking of keeping this motor and build it up since its burning some oil which i think is valve seal in cylinder 2 cause the plug was wet in oil. so i pretty much need some site that offer internals for this motors. those anyone know about how much power this motors are capable of producing?
thanx for any info
Old May 18, 2008 | 06:25 PM
Bseriescivic5's Avatar
Bump for more information on the f23 series.....i myself am a guru of the b-series....sry
Old May 19, 2008 | 04:39 AM
GhostAccord's Avatar
Default Re: Need Help To Build My F23A4 up (mike0216)
There is relatively no aftermarket/performance support for the F23 engine at the moment. And since the K series came out it may be a while before you see any mass F23 movement. It's taken forever for the F22 to get some support. And the parts aren't cheap. Any money that you put into the F will be lost if you end up going to an H, none of the parts are interchangeable. If you want to do an H swap save your money by leaving the F23 as is.
Old May 24, 2008 | 11:22 AM
NASOHC's Avatar
I'm putting over 150whp on my F23A4 w/ Cam and all the bolt ons available w/ H23 trans. Not much room for more gains so I'm building an NA SOHC F22A1 (CB7) to swap instead.
Antonio Casco
Mar 5, 2019 10:07 AM
BizKut77❤myCB7
Jan 8, 2018 12:31 PM
JDM_Ryan
31
Mar 18, 2011 11:39 AM
m6gryder
Nov 12, 2007 11:27 PM
xCIVICx
12
Oct 20, 2005 11:46 AM
