b16 swap
Old Apr 18, 2008 | 01:00 PM
b16delsolnewb's Avatar
Default b16 swap
hey guys,
just finished my del sol swap last night and the car starts and run.
i have couple of issues with the car.
1st issue - white smoke coming out of the exhaust
2nd - catalytic converter is getting so hot to the point that i looks like a coal in a grill.
3rd - the car doesnt have power over 4k rpm
i dont have the 02 sensor installed yet because the headers that i got doesnt have the hole for it. ordered headers just waiting in the mail.
vtec harness hasnt been fix yet. still working on it.
anything else i should think of or check to finisht it?
Old Apr 18, 2008 | 01:06 PM
CTR_B's Avatar
Default Re: b16 swap (b16delsolnewb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16delsolnewb &raquo;</TD></TR><TR><TD CLASS="quote">hey guys, just finished my del sol swap last night and the car starts and run.
anything else i should think of or check to finisht it?</TD></TR></TABLE>
First thing is you dont have two exhaust manifolds you have one so it would be "header" with that out of the way
your converter is plugged an would be the reason it is glowing and result in loss of power and the fact the vtec come in the 5k range would be another loss in power. Fix your problems and try it again an come back and report
Old Apr 18, 2008 | 01:08 PM
philosofy1's Avatar
after fixing your power loss from no vtec and a clogged cat, i would looking into a compression test. white smoke out of the exhaust is not a good sign.
Old Apr 18, 2008 | 01:13 PM
CTR_B's Avatar
Default Re: b16 swap (philosofy1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 &raquo;</TD></TR><TR><TD CLASS="quote">
after fixing your power loss from no vtec and a clogged cat, i would looking into a compression test. white smoke out of the exhaust is not a good sign. </TD></TR></TABLE>
There could be a simple reason for that though...
When people transport/store an engine some times there dont completely drain the fluids. an on start up could be burned threw the engine. other wise known as burn off. After fixing the vtec and cat let it run for a little then take it out for an easy spin. If you continue to see white smoke look into the compression test.
Old Apr 18, 2008 | 01:14 PM
philosofy1's Avatar
Default Re: b16 swap (CTR_B)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CTR_B &raquo;</TD></TR><TR><TD CLASS="quote">
When people transport/store an engine some times there dont completely drain the fluids. an on start up could be burned threw the engine. other wise known as burn off. After fixing the vtec and cat let it run for a little then take it out for an easy spin. If you continue to see white smoke look into the compression test. </TD></TR></TABLE>
Old Apr 18, 2008 | 01:41 PM
thanks for all you guys help. its just a closure on what i thought the problem is. thanks u guys are awesome.
dtarvin
10
Mar 18, 2008 05:20 PM
sti runnen it
Oct 19, 2007 11:09 AM
hondaconcept
Feb 9, 2007 04:46 PM
droptop
40
Jul 10, 2002 05:06 PM
