Oil Question
Old Apr 18, 2008 | 12:36 PM
jit01's Avatar
Default Oil Question
Hi I have a 95 del sol vtec (b16a3) I am switching to synthetic oil royal purple 5w 30.. is it good if I change the oil every 8000k but switch the oil filter every 4k ? by the way my car has 137k on it.
Old Apr 18, 2008 | 12:42 PM
philosofy1's Avatar
Default Re: Oil Question (jit01)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jit01 &raquo;</TD></TR><TR><TD CLASS="quote">Hi I have a 95 del sol vtec (b16a3) I am switching to synthetic oil royal purple 5w 30.. is it good if I change the oil every 8000k but switch the oil filter every 4k ? by the way my car has 137k on it. </TD></TR></TABLE>
me personally, i change the filter when i change the oil.
Old Apr 18, 2008 | 12:44 PM
blk92_d16's Avatar
Throw a K&N on it and change both at the same time. Aren't their rated for 7 or 8k miles?
Old Apr 18, 2008 | 12:45 PM
jit01's Avatar
Default Re: Oil Question (philosofy1)
aren't you supposed to change the filter at 4k tho ? also 8k is a good time to change the oil right ?
I use oem honda filters
Old Apr 18, 2008 | 12:58 PM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jit01 &raquo;</TD></TR><TR><TD CLASS="quote">aren't you supposed to change the filter at 4k tho ? also 8k is a good time to change the oil right ?
I use oem honda filters </TD></TR></TABLE>
i also use oem honda filters!
when my civic (JDM B16A) was my DD, i changed the oil every 3K along with the filter. though it was conventional oil, i think i would probably do the same, i mean damn, i would change my tranny fluid every 6K or 6 months.
now that it's my weekend car and i seldomly drive it once a week, i have stretch the oil change to about 6 months and tranny to once a year.
i know the synthetic oils can go up longer and newer motor can too, but i'm not sure about waiting to 8K. maybe 4K-5K for both?
Old Apr 19, 2008 | 01:38 PM
jit01's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 &raquo;</TD></TR><TR><TD CLASS="quote">
i know the synthetic oils can go up longer and newer motor can too, but i'm not sure about waiting to 8K. maybe 4K-5K for both?</TD></TR></TABLE>
Ya I guess I am gonna switch to every 5k now. That would be fine right ? When I used the regular oil I changed it every 3k.
gents97civ's Avatar
Give amsoil a try, you can go up to 25,000 on a single filter. Also the oil last much longer between changes than other oils.
Old Apr 19, 2008 | 01:39 PM
jit01's Avatar
Default Re: (gents97civ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gents97civ &raquo;</TD></TR><TR><TD CLASS="quote">Give amsoil a try, you can go up to 25,000 on a single filter. Also the oil last much longer between changes than other oils. </TD></TR></TABLE>
I just changed my oil to royal purple today hope its good and doesnt burn off quick..
Old Apr 19, 2008 | 01:44 PM
Ice78transam's Avatar
Default Re: (jit01)
RP is a waste of money. Its good but not any better than others. and if you drive aggressively change your oil every 3-4k miles with synthetic. Its called preventative maintenance. all the money you save not buying RP you can spend on more frequent oil changes with Syntec, for example.
my .02
Old Apr 19, 2008 | 01:46 PM
Frickr's Avatar
i love amsoil, i dont tihnk ill run any other oil from now on. i use a Pureone filter, and i got between 4500, and 5000 on this change and my oil is still clean. also with amsoil, if your really worried about running your oil for high mileage, they have an oil analys service and will send you a detailed report of how dirty your oil is, if you have any excess metel or any other things that can be harmful to your motor.
Old Apr 19, 2008 | 02:48 PM
ekpunker's Avatar
Default Re: (Frickr)
Quaker State Q Horsepower is an amazing oil. It used to be Advanced Engine I believe.
Even after 3000 miles of "spirited" and regular driving, the oil hardly ever gets darker than it does when it's brand new. And it's not terribly expensive.
Old Apr 19, 2008 | 03:52 PM
HeikDiesel's Avatar
Default Re: (ekpunker)
Instead of blowing 50 bucks on a oil and filter combo that lasts 3896t75234863 miles, why not just run normal oil and a OEM filter and change it every 3,000 miles. I'll live by that till the day I die
Old Apr 19, 2008 | 06:33 PM
Default Re: (HeikDiesel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HeikDiesel &raquo;</TD></TR><TR><TD CLASS="quote">Instead of blowing 50 bucks on a oil and filter combo that lasts 3896t75234863 miles, why not just run normal oil and a OEM filter and change it every 3,000 miles. I'll live by that till the day I die</TD></TR></TABLE>
Dat a boy +1
Old Apr 19, 2008 | 06:50 PM
Frickr's Avatar
i dont use my oil just because i get extended drain times, but after the point when conventional oil is dirty and broke down, and causing wear, my oil is still clean and has the same lubrication proporties. so in the long run, im saving on wear, and i actually save money running synthetic, i get 1 change for synthetic, to 2 i would get out of conventional for 10 dollers a change more. ill find that i'll run into the 6 month time line, verse the miles. i also burn off less oil in a x amout of miles that i would have to add a quart of conventional, i dont need to add any. and im the type that checks every time i fill my car up.
Old Apr 19, 2008 | 07:50 PM
B20EF's Avatar
I take my DD to the dealership for oil changes cause it's only $30 and the sticker they put on my windshield says I'm not due for another 8000km
Old Apr 19, 2008 | 10:51 PM
HeikDiesel's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Frickr &raquo;</TD></TR><TR><TD CLASS="quote">
i dont use my oil just because i get extended drain times, but after the point when conventional oil is dirty and broke down, and causing wear, my oil is still clean and has the same lubrication proporties. so in the long run, im saving on wear, and i actually save money running synthetic, i get 1 change for synthetic, to 2 i would get out of conventional for 10 dollers a change more. ill find that i'll run into the 6 month time line, verse the miles. i also burn off less oil in a x amout of miles that i would have to add a quart of conventional, i dont need to add any. and im the type that checks every time i fill my car up.</TD></TR></TABLE>
Not to be a dick, but if you can't spell dollars, don't tell me about the properties of oil and its molecular structure
Old Apr 20, 2008 | 08:43 PM
Not to be a dick, but if you can't spell dollars, don't tell me about the properties of oil and its molecular structure </TD></TR></TABLE>
Zing!
But he's entitled to his own synthetic loving opinion.
Old Apr 21, 2008 | 05:25 PM
ahron's Avatar
at 137k. i would go to 10w 30. 5w30 is the base weight.. i'd go thicker than 5w30 since the motor got that much mileage. your motor is juss gonna eat that oil quick. im a lube tech and i see alot of peaople still putting 5w30 on high milage cars. i say 10w30. honda manufacture recomend that u should change oil ever 4,500 miles, wit filter. wit synthetic, i wouldnt push more than six. i say change it every 6, wit filter. i use mobile 1 synthtic, its great. i change oil every 4000 miles. i 8k is way to long for an oil change. there are oil companies that state their oil last 10k 50k. I think its bull.. changing oil 3k-4k is the best way to go. if regular oil is being used. i recommend every 3k. dont use regular pennzoil btw. they suck
Old Apr 21, 2008 | 06:59 PM
themunchkinman's Avatar
Default Re: Oil Question (ahron)
"Lube Tech" - please elaborate. Also, I haven't had much bad experience with Pennzoil, so please shed some light on "they suck".
- Thanks.
foowitdaredek
Jun 1, 2007 12:37 PM
yujintheman
Honda Civic (2006 - 2015)
Feb 9, 2007 06:26 PM
NA4sho
Dec 26, 2006 05:49 AM
InFaMoUs GsR
Nov 4, 2004 07:10 AM
lowgman
Apr 21, 2004 04:14 PM
