GSR Disk swap to ITR Disk swap
Old Apr 18, 2008 | 12:24 PM
Momentum's Avatar
Default GSR Disk swap to ITR Disk swap
My 92 EG currently has the GSR brake swap all the way around... and im looking to install the ITR swap, mainly just for the 4x114 bolt pattern.
I have all the parts needed for the ITR swap, including ITR wheels... just wondering if its any different doing the rears as it would be from going from stock brakes to ITR. Or would i just be able to follow a stock brake to ITR tutorial?
Any idea how hard it is to do, how long it should take?
Do I have to change the ebrake cables?
Old May 13, 2008 | 01:17 PM
Momentum's Avatar
BUMP
Old May 13, 2008 | 02:57 PM
99B19CEK's Avatar
Default Re: GSR Disk swap to ITR Disk swap (Momentum)
You should be able to bolt it right on, no mods needed as long as you have the whole assembly. lines, and control arms will work.
I am a noob, but I used to do swaps and conversions for years.
cBrown05
Suspension & Brakes
Apr 27, 2010 07:43 AM
sloweredcivic
12
Jan 14, 2008 06:28 PM
SplitEagle
Mar 25, 2006 01:02 PM
Yellow Dragon
Jan 14, 2003 09:33 AM
