Camber?
Old Apr 18, 2008 | 11:38 AM
93CamaroLT1's Avatar
Default Camber?
Can a wheel alignment adjust rear camber on a 99 SI?.. It's at stock ride height, yet i'm seeing camber where on the insides of the tires.
Old Apr 18, 2008 | 12:12 PM
philosofy1's Avatar
Default Re: Camber? (93CamaroLT1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93CamaroLT1 &raquo;</TD></TR><TR><TD CLASS="quote">Can a wheel alignment adjust rear camber on a 99 SI?.. It's at stock ride height, yet i'm seeing camber where on the insides of the tires.</TD></TR></TABLE>
no, factory suspension is set at that with no camber adjustment. on a factory suspension, you shouldn't need any camber adjustment unless it has been modified or damage due to some sort of accident.
are you sure what you are seeing is camber and not toe?
Old Apr 18, 2008 | 12:21 PM
Default Re: Camber? (philosofy1)
Not sure; all I can see is the wheels slant outward a bit (not very noticeable even) and the insides of the tires are worn are significantly more than the rest of the tire.
Old Apr 18, 2008 | 12:23 PM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93CamaroLT1 &raquo;</TD></TR><TR><TD CLASS="quote">Not sure; all I can see is the wheels slant outward a bit (not very noticeable even) and the insides of the tires are worn are significantly more than the rest of the tire.</TD></TR></TABLE>
if you are sitting on a stock suspension and the car was never in a accident (to your knowledge), then i would say you are looking a toe. they can almost look the same if it's not that bad, especially the rear tires.
Old Apr 18, 2008 | 02:15 PM
EK_B's Avatar
Get your suspension checked at a shop and get an alignment at the same time.
Touge Monsta
Aug 1, 2008 05:02 PM
jdmturbo1127
Suspension & Brakes
96
Sep 7, 2007 08:57 AM
Flava
Suspension & Brakes
26
Jun 9, 2006 08:56 AM
h3avyarms
24
Oct 26, 2004 12:57 PM
fluidaccord1
Aug 6, 2003 12:16 AM
