Classic Hondas All Pre-1988 Hondas.
1988 accord hatchback
Old Apr 18, 2008 | 11:31 AM
accord0506's Avatar
Default 1988 accord hatchback
I have a 1988 accord hatchback. I new to the import scene i was wondering how should i build my car for street racing i would to be in 11 sec if possible! i have 2.0liter pfi engine ( i think it call b20 motor)not for sure though. i also have a 5 speed. all i have done to it is shorten the shifter like 4-6 inches put 2 1/4 inches pipes and muffler and a cold air intake that sucks from the front of the car but that all i done to it so far. I dont know much on the import motor have been in trucks, camaro and trans am all my life so any help would be appreciate
Modified by accord0506 at 11:26 PM 4/18/2008
Old Apr 18, 2008 | 02:54 PM
88LXi68's Avatar
it is tough to build an 11 sec street car, let alone using an 88 Accord. It can be done, but be prepared to spend some money or know people who can do good fab work.
The b20a is in the JDM version of the car. the engine you probably have is an A20A3, which is a good boost engine as it is cast iron and has a closed deck compared to many honda engines. the problem is that the head doesnt flow the greatest stock and the intake manifold sucks, that can all be fixed though with a good head porter and aftermarket intake manifold. there are no turbo "kits" or pistons/rods/cam actually made for it. so custom and mix matching parts is the name of the game. i have been out of the a20 game for a while so I can not tell you exactly what is available or can be used. I have an 88 LXi coupe that I swapped a newer B-series engine into...so you can make these cars go.
Anyway, you can make it an 11sec ride, but it will take time, patience, and creativity.
also, try http://www.3geez.com lots of turbo info there!
Old Apr 18, 2008 | 10:35 PM
accord0506's Avatar
Default Re: (88LXi68)
thanks for the help i will check into that stuff thanks again
Modified by accord0506 at 11:44 PM 4/18/2008
Old Apr 19, 2008 | 07:03 AM
KILLAB17VTEC's Avatar
Genetically Gay
Default Re: (accord0506)
u got accord chasiss u should try to see if da h22vtec drop rite in.
Old Apr 19, 2008 | 10:16 AM
accord0506's Avatar
Default Re: (KILLAB17VTEC)
ill check into that thanks
Old Apr 19, 2008 | 12:54 PM
TheMuffinMan's Avatar
He knows where you live!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KILLAB17VTEC &raquo;</TD></TR><TR><TD CLASS="quote">u got accord chasiss u should try to see if da h22vtec drop rite in.</TD></TR></TABLE>
No, a H22 is a drop in for the CB/CD/CG chassis NOT the old ones.......
A B series is the drop in for the older model Accords.
(lol first post in this section)
Old Apr 20, 2008 | 06:38 AM
nicokpe's Avatar
No, thats a little different type. what the said of "TheMuffinMan" was right
Old Apr 30, 2008 | 07:03 PM
2DrSE-i's Avatar
Default Re: (nicokpe)
B-series dont even "drop in". the only motor that drops in is the B20A8, which ONLY came in the JDM/EDM/NZDM(lol) accord of that era. The others require mounts, axles, etc.
Old May 6, 2008 | 05:31 PM
1987AccordLx-i's Avatar
Default Re: (2DrSE-i)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2DrSE-i &raquo;</TD></TR><TR><TD CLASS="quote">B-series dont even "drop in". the only motor that drops in is the B20A8, which ONLY came in the JDM/EDM/NZDM(lol) accord of that era. The others require mounts, axles, etc.</TD></TR></TABLE> the b20a1 blacktop will fit.. goldtop will fit in the pre 88 models
Old Jun 12, 2008 | 11:11 AM
r_Senik's Avatar
Default Re: (1987AccordLx-i)
id say drop a b-series in it...but i heard the company that used to make the mounts discontinued them...iono i want a accord hatch too!
Old Jun 22, 2008 | 03:13 PM
89accord_lxi's Avatar
Default Re: (r_Senik)
So Im new to all this. i have a 89 lxi. i need a swap for it. im not looking to break the bank, just something to get it driving again. all my buddies are civic guys. so they are worthless right now lol . what do i need to be looking for? best would be something more or less drop in and go but i can do more if i need.
if you can help id appreciate it.
Old Jun 26, 2008 | 11:48 AM
EFinawesomeman's Avatar
Default Re: (89accord_lxi)
go to the junkyard and find a b20 and transmission in an older prelude. take it out, re build it and clean the snot out of it. drop it in, take it out. and have fun.
Old Jul 6, 2008 | 03:49 AM
89turboaccord's Avatar
Default Re: (EFinawesomeman)
the usdm b20 is not a drop in.
Old Jul 15, 2008 | 11:41 AM
Default Re: (89turboaccord)
correct.. the usdm is straight lined motor.. meaning it doesnt lean front or back.. the jdm B20A1 slants toward the radiator.. so if the op is gunna get a B20 then he should look for the one that slants toward the radiator
Old Aug 1, 2008 | 06:05 AM
markmdz89hatch's Avatar
The B20 for our Accords was never brought to the US in any Honda, but it was a factory motor option in our Accords anywhere other then the America's, so you won't need to do much of any custom fabrication to make the swap. The only way to get a B20 to just drop in there is to pick one up from an engine importer, or find someone here in the states that already has one and is willing to sell.
89accord_lx1: Just curious... ...when you say "just something to get it driving again" am I to assume that your motor is shot? If so, and you're concerned with getting it going, just go to a junkyard and get yourself another A20 for next to nothing. They're a dime-a-dozen b/c no one wants them, and there's millions of 3rd gen Accords out there, so there's no demand at all.
Once you do that, you can build up the A20 to make some pretty respectable horsepower, and if you wanted to you could even boost it and make some damn good power relatively cheap. With the cast iron block of the A20, and long stroke, it makes it a great block to boost b/c of it's strength. Where you'll run into power limitations is at the head due to a single cam not allowing as much flow as a dohc.
Old Aug 2, 2008 | 12:59 PM
accord0506's Avatar
Default Re: (markmdz89hatch)
so can i put dohc head on that a20 motor that is in the 88 honda accord or there something i can do that head that will make it breathe better any help would be great thanks
Old Aug 4, 2008 | 04:41 PM
import_boi1's Avatar
Default Re: 1988 accord hatchback (accord0506)
build the motor and turbo it, redo all the suspension and get stonger axles
stingray109
Jul 9, 2015 12:57 AM
pliskin679
Jul 22, 2013 05:37 PM
costumer
Aug 5, 2009 07:41 AM
AndrewJ
Aug 2, 2002 04:21 AM
Ochux
Sep 28, 2001 09:30 PM
