Rear Caliper Piston/Rubber Boot
Old Apr 18, 2008 | 08:28 AM
Dunc's Avatar
BCICAN
Default Rear Caliper Piston/Rubber Boot
Background:
Near the end of winter (like a month or two ago) I would notice that the rear driver side brake was dragging bad when I went to work in the mornings. It was especially bad if I used the parking brake.
I opened everything up this week and found that the the piston (while intially very stiff, so assuming rust) was able to retract back in. I then noticed the rubber boot around the piston didn't look good.
Question:
Is this repairable? Or is it easier just to get a new caliper and call it a day? I'm just not in the mood to chase down stupid problems like this much anymore so I'd like to get a fix that will work the first time.
Picture of the caliper:
- I sprayed a bunch of penetrating lube on it so free it up.
http://i130.photobucket.com/albums/p...4/103_1109.jpg
Old Apr 18, 2008 | 09:24 AM
JETSPD1477's Avatar
Default Re: Rear Caliper Piston/Rubber Boot (Dunc)
of course it would be easier to just replace the caliper.
depending on your budget rebuilding/reconditioning the caliper would be a lot cheaper.
Old Apr 18, 2008 | 09:47 AM
super jdm yo's Avatar
Default Re: Rear Caliper Piston/Rubber Boot (JETSPD1477)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JETSPD1477 &raquo;</TD></TR><TR><TD CLASS="quote">of course it would be easier to just replace the caliper.
depending on your budget rebuilding/reconditioning the caliper would be a lot cheaper.</TD></TR></TABLE>
i thoughts exactly. but since i've never re-build a caliper i say just replace it.
Old Apr 18, 2008 | 10:11 AM
Dunc's Avatar
BCICAN
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JETSPD1477 &raquo;</TD></TR><TR><TD CLASS="quote">of course it would be easier to just replace the caliper. depending on your budget rebuilding/reconditioning the caliper would be a lot cheaper.</TD></TR></TABLE>
Yea I looked up a caliper and it looks like a "RMD" (I assumed re-manufactured oem one from Acura) is ~$130. New is ~$230. So I'm guessing my price would be around 200.
I wouldn't mind learning how to rebuild one....more for the knowledge than to save a couple bucks. Has anyone ever done this here? Any input on level of difficulty and quality of final product?
EDIT: For future readers, I found the answer to my question:
Rear (Click here)
Write Up (Click here) &lt;--Same concept for the rears
Modified by Dunc at 2:31 PM 4/18/2008
Old Apr 18, 2008 | 11:04 AM
you know it doesn't look that bad to do. maybe next time i change my pads i'm gonna see it i need this done. goodluck.
Old Apr 18, 2008 | 04:04 PM
Blahblah718293's Avatar
Default Re: Rear Caliper Piston/Rubber Boot (super jdm yo)
its not that bad, you pretty much just take out the piston and replace the seal. thats the front ones anyway, rears are more complex cause of the parking brake. but just set a good day away and youll get it done.
Old Jul 2, 2008 | 09:22 PM
teg your it's Avatar
Default Re: Rear Caliper Piston/Rubber Boot (Blahblah718293)
i have the same problem. except my caliper seem to be working just fine but the piston boot is torn. friends told me it prevent dirt from getting in so i bought a new piston boot at the dealer.
do you have to take out the piston itself in order to replace just the boot?
mfrs
Sep 9, 2014 03:49 PM
milanoteg
Suspension & Brakes
Mar 8, 2010 10:17 AM
maxdb
Apr 28, 2005 04:16 PM
OBD1Kenobe
Sep 30, 2004 08:17 PM
D
Aug 6, 2001 06:21 AM
