OBD 1 D15 into 97 Civic EX
Just got finished with the swap and was wondering which ECU I need to run in order to have no CEL's. The D15 block has 2 less sensors than the D16Y8 Block, one is on the back of the block and the other is on the crank. Do I need to run an OBD 1 Non VTEC ECU to clear everything up?
yyyep
crank position sensor and...knock sensor? does a y8 have a knock sensor? no need for the second o2
so i think its a P06 that you need, i just hate you had to make that trade from y8 to b7, or worse, b8
Justinrobi21
Mar 26, 2015 03:11 PM
Littleredsi
May 30, 2004 10:06 AM
