ecu help! code 21 and idling problem.
Old Apr 17, 2008 | 09:20 PM
ToeJam's Avatar
Default ecu help! code 21 and idling problem.
I suspect that there may be something wrong with my ecu. Every time the ecu is moved I would get code 21 with very bad idling and reving problems. After resetting the ecu and setting it completely flat on the passenger side floor, the code and the idling problems will go away until it is moved or mounted back up.
I remember reading somewhere that there is a resistor or capacitor that can go out and cause this problem.
If you know what maybe be causing this problem please help.
Old Apr 17, 2008 | 09:34 PM
civicstar's Avatar
Default Re: ecu help! code 21 and idling problem. (ToeJam)
could be a ground near the ecu
Old Apr 19, 2008 | 05:17 PM
ToeJam's Avatar
Default Re: ecu help! code 21 and idling problem. (civicstar)
ground is good on the Tstat housing.
bump for more answers..
B18CmeFLYby
Mar 23, 2007 01:54 PM
BpuTacoma
Apr 2, 2003 09:44 PM
