Rear Brake Question
Old Apr 17, 2008 | 08:05 PM
SOHC4life 96's Avatar
Default Rear Brake Question
I need to know if I can take the entire hub off of a rear disc trailing arm and put it on a rear drum trailing arm.
Old Apr 17, 2008 | 09:24 PM
melsers's Avatar
Default Re: Rear Brake Question (SOHC4life 96)
yes. take off the 4 torx bolts and the 24mm nut and it comes right off. trailing arms are the same, brake lines and e-brake lines are not
Old Apr 17, 2008 | 09:31 PM
92egSnatch's Avatar
Default Re: Rear Brake Question (melsers)
gigidy gigidy gigidy
i was wondering the same thing thanks
Old Apr 17, 2008 | 10:14 PM
Default Re: Rear Brake Question (92egSnatch)
BRILLIANT!!! Thank you very much Melsers!
Old Apr 18, 2008 | 02:57 AM
pimpvw's Avatar
its way easier to just swap out the wole trailing arm than trying to get those 4 orx bolts out
Old Apr 18, 2008 | 05:41 AM
Default Re: Rear Brake Question (pimpvw)
My trailing arm is bent, so that is my only option.
Old Apr 18, 2008 | 04:00 PM
melsers's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pimpvw &raquo;</TD></TR><TR><TD CLASS="quote">its way easier to just swap out the wole trailing arm than trying to get those 4 orx bolts out</TD></TR></TABLE>
yeah they strip very easily. if you have trouble, just hammer a 14mm easy-out onto it and use a breaker bar.
dth0ng69
Oct 24, 2009 09:55 PM
huge230
Aug 23, 2005 12:28 PM
wdskuk
11
Jul 6, 2004 11:08 AM
HYBRIDHATCH92
Apr 23, 2002 02:40 PM
