cams in b18 or b16 head?
Looking for a mild upgrade to my 95 gsr. Dont want to spend too much and not looking for a big build. Just looking to get around 200hp or a little more.
I've heard that you can just put a set of stage 1 cams into a b18 without changing the valvetrain. Is this true? If it is, what would give a better gain... stage 1 cams in my b18 or putting a b16 head on it with b16? b18? cams.
thinking right now about maybe skunk2 pro series stage 1 cams and a intake mani...thoughts? will I need upgraded head internals?
New to the honda scene (previously dealt with dsms) so any info will be helpful.
Have a comptech intake and a greddy exhaust mani right now.
Modified by spidy3 at 8:22 PM 4/17/2008
Modified by spidy3 at 8:42 PM 4/17/2008
You do not want to put the B16 head on the GSR block, it will decrease your compression. Skunk2 states that you can use the stage 1's without a valvetrain but it is recommended to upgrade that. The stage 1's are just a tiny bit bigger than OEM ITR cams which you can use without upgrading valvetrain but not to its fullest(can't rev too high without risk). The stage1's and a IM will be decent if thats what you want.
I personally have 01 ITR cams and springs with a Skunk2 IM and love them both.
dElSleepiE
Apr 28, 2003 09:16 PM
