brake problemmmmm (please help)
Old Apr 17, 2008 | 05:36 PM
b18b1ef8's Avatar
Default brake problemmmmm (please help)
mi brakes dont work
i tried bleedin them like 4 times
i had tha master cylender replaced and bleed and tha brake still goes to tha floor with no presure
pleasee helpp
wat else could it be ?
Old Apr 17, 2008 | 10:10 PM
neozero999's Avatar
Default Re: brake problemmmmm (b18b1ef8)
hmmm did you bench bleed the MC? also did you get the right MC, cause im not too sure but pushrod lengths matter usually.... also hows your brake booster doing?
Old Apr 18, 2008 | 04:57 AM
Voodooboy520's Avatar
Default Re: brake problemmmmm (neozero999)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neozero999 &raquo;</TD></TR><TR><TD CLASS="quote">hmmm did you bench bleed the MC? also did you get the right MC, cause im not too sure but pushrod lengths matter usually.... also hows your brake booster doing? </TD></TR></TABLE>
Brake booster shouldnt have anything to do with it, it just helps you push the pedal. There is either a leak in the system or air in your MC, troubleshoot until you find which one it is.
Old Apr 18, 2008 | 05:31 AM
b18b1ef8's Avatar
ok thanks im not to sure but i think i have a leak in one of mi lines
jwlee7ucla
Apr 14, 2024 07:41 AM
hteg12
Jul 18, 2013 05:13 PM
kelviiv
Jan 9, 2011 11:31 AM
boostedteg1203
Jan 21, 2010 05:58 AM
tilt
Mar 11, 2003 08:52 PM
