Hondata HondaLogger s200
Old Apr 17, 2008 | 03:01 PM
mastakmk's Avatar
Default Hondata HondaLogger s200
hey, i was wondering, has anyone used the hondalogger program from hondata? i am having a connection problem. and dont know what to do about it. should i contact hondata? i have windows vista. . came on my laptop. pff help?
Old Apr 17, 2008 | 04:51 PM
EARLdaSQUIRREL's Avatar
official honda whore
Default Re: Hondata HondaLogger s200 (mastakmk)
make sure j12 is cut and have your port number under 9
Old Apr 17, 2008 | 06:41 PM
mastakmk's Avatar
Default Re: Hondata HondaLogger s200 (EARLdaSQUIRREL)
got it. its port 5 for me... i was beginning to get worried. lol. thanks. i figured it out at a local car meet. lol cops came as i left to do a test run and made them all clear the lot. haha.. i got my runs.
Old Apr 17, 2008 | 06:51 PM
so it was the port #?
Old Apr 19, 2008 | 03:48 PM
IN VTEC's Avatar
I couldn't use a USB to serial converter in my datalogging cable. It had to be a serial cable. If I tried to use the USB converter, it would drop the connection within 20 seconds of hitting the F10 button.
Old Apr 22, 2008 | 10:45 AM
b19coupe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EARLdaSQUIRREL &raquo;</TD></TR><TR><TD CLASS="quote">make sure j12 is cut and have your port number under 9</TD></TR></TABLE>
The port number is not going to be the same for all laptops. If you have Device Manager open in Windows, and are looking at the ports, you can see which port is getting assigned to your cable when you plug it in.
Old Apr 22, 2008 | 11:53 AM
Default Re: Hondata HondaLogger s200 (b19coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe &raquo;</TD></TR><TR><TD CLASS="quote">
The port number is not going to be the same for all laptops. If you have Device Manager open in Windows, and are looking at the ports, you can see which port is getting assigned to your cable when you plug it in.</TD></TR></TABLE>
correct, but if your laptop is like mine , none of the ports are 10 or below, so i had to go into the device manager and manually change the port to a lower number
Nathan_volcom
Engine Management and Tuning
Jan 27, 2012 01:37 AM
VolkswagenWHO!!!
Aug 21, 2011 02:19 AM
CaymanNational
Jan 5, 2008 07:33 AM
boosted92
Aug 16, 2003 09:08 AM
txhatch
Oct 1, 2002 01:19 PM
