AC on gsr ek hatch question...
Old Apr 17, 2008 | 02:13 PM
o0ohaviko0o's Avatar
Default AC on gsr ek hatch question...
What all do I need. I dont have any ac lines or anything. I been told I need a certain AC bracket to but the compressor in. Does anyone know what bracket, compressor, and lines I need.
Old Apr 17, 2008 | 02:22 PM
B18CivicEJ8's Avatar
Default Re: AC on gsr ek hatch question... (o0ohaviko0o)
If you are starting ground zero with no A/C at all, your best bet is to get an entire system out of a 99-00 Civic Si from a junk yard. It will be a straight bolt on affair.
Did your car come w/ A/C from the factory at all?
Old Apr 18, 2008 | 06:22 AM
Default Re: AC on gsr ek hatch question... (B18CivicEJ8)
It has the AC components from under the dash. But all the under the hood dash parts are missing. Just need to know what kind of bracket, lines and compressor I need to run it on my gsr.
Old Apr 18, 2008 | 06:27 AM
geebs's Avatar
del sol VTEC ac mount/bracket.. P30 i think.. you can also use the CRV aluminum bracket..
D series compressor.. any 96-00 civic a/c system.. condensor, condensor fan, hoses, metal lines...
you want basically everything from your model car minus the ac bracket from the del sol or crv..
moz92
Aug 13, 2008 10:55 PM
rezneffix
May 16, 2007 09:54 PM
Turbotype
Dec 2, 2004 03:02 PM
Propulsion
Aug 12, 2002 10:13 PM
