trans how much????
Old Apr 17, 2008 | 01:30 PM
fatman69's Avatar
Default trans how much????
yea i have a felling my trans is guan go out on me i notice for the last couple weeks that when i shift from park to drive the car jerks or studders, could this be the trans going or sum thing else its a 1997 accord LX with only 72,657 miles that seems like not that many miles for an automatic tran to be going out, so if any 1 has any ideas pliz tell me
Old Apr 17, 2008 | 02:03 PM
FunnyVictor86's Avatar
Default Re: trans how much???? (fatman69)
well my auto on my old '99 accord cost me $1600 to do a full rebuild ... i didnt want to take my chances at a junk yard ...
Old Apr 17, 2008 | 04:33 PM
rirc's Avatar
700 for a used transmission, about 1500 include labor.
Old Apr 17, 2008 | 06:21 PM
donpisto's Avatar
Sounds like the transmission to me. My '02 Accord's tranny starting going out at about 90k. Apparently Accord auto transmissions are known to have that issue, at least for my gen. My mechanic charged me 1,000 for a rebuilt engine which included labor. Mine would SEVERELY just jerk and it sounds like you had the same issue I did.
My mechanic also recommended changing the transmission oil every 15,000 miles to lengthen the life of the transmission.
Old Apr 17, 2008 | 07:29 PM
Default Re: trans how much???? (donpisto)
you can also get an external aftermarket oil cooler ... rather than the built in oil cooler that runs within the radiator ...
Old Apr 17, 2008 | 07:55 PM
tpot90's Avatar
Default Re: trans how much???? (FunnyVictor86)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FunnyVictor86 &raquo;</TD></TR><TR><TD CLASS="quote">you can also get an external aftermarket oil cooler ... rather than the built in oil cooler that runs within the radiator ...</TD></TR></TABLE>
Unless your motor is fully built, the affects are not going to be noticable.
Just because your tranny jerks a little bit from Park to Drive doesnt mean its going out. Try changing your fluid first.. If that doesnt help, look into other options.
Rebuilds or swaps should be the last resort because of the costs..Unless you have a bunch of money to play with.
Old Apr 17, 2008 | 10:44 PM
Honda_Accord's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by donpisto &raquo;</TD></TR><TR><TD CLASS="quote">Sounds like the transmission to me. My '02 Accord's tranny starting going out at about 90k. Apparently Accord auto transmissions are known to have that issue, at least for my gen . My mechanic charged me 1,000 for a rebuilt engine which included labor. Mine would SEVERELY just jerk and it sounds like you had the same issue I did.
My mechanic also recommended changing the transmission oil every 15,000 miles to lengthen the life of the transmission.</TD></TR></TABLE>
i want to clarify this.. 94-97 accord have bulletproof trans 99 percent of the time.. 156k and not one problem with my tranny i change fluid when im suppose to.. ALSO 5th gen ( 94-97) are known to jerk and stuff when shifting its just normal
try changing ur tranny fluid with Honda ATF and nothing else, see if that helps.. i think it suppose to be changed ever 30k miles if im not mistaken, just take out the stick by the tranny on the passanger side (when u face the window) and see if its a pinkish
Old Apr 18, 2008 | 09:14 AM
Default Re: trans how much???? (Honda_Accord)
of course its a must have on a full built ... but when trans fluid gets too hot and theres slight slipping ... my auto would do that in my harsh driving days ...
Old Apr 18, 2008 | 09:44 AM
bseriescrxsi's Avatar
94 -97 models have the tans cooling lines on the radiator(at least the vtec models do anyway) but unlike the 90-93 they dont have the lines coming off the back of the motor
wmflyfisher
Dec 9, 2012 12:28 PM
1996accordlx22
Aug 5, 2012 07:30 AM
Crider4_6
Nov 15, 2011 08:30 AM
J Taylor
May 16, 2010 07:17 PM
HOOT972
Mar 14, 2010 08:27 AM
