would an exhaust leak cause me to bog???
Old Apr 17, 2008 | 01:01 PM
unsungfate's Avatar
Default would an exhaust leak cause me to bog???
at startup while cold?? i have to let the car warm up or else it takes *****... but once warmed up, runs strong.
also i got me some 00 type r cams, can i run them with my stocks valve springs with out any problem... my ecu engages v tec at 6k and redlines to 10k... but i never take it past 8.5 with the type r cams, should i play it even safer and lower it or am i good?
Old Apr 17, 2008 | 01:48 PM
unsungfate's Avatar
Default Re: would an exhaust leak cause me to bog??? (unsungfate)
bump?
Old Apr 17, 2008 | 05:51 PM
unsungfate's Avatar
come on... no one will chime in???
Old Apr 17, 2008 | 06:00 PM
obuhmyuh's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by unsungfate &raquo;</TD></TR><TR><TD CLASS="quote">at startup while cold?? i have to let the car warm up or else it takes *****... but once warmed up, runs strong.
also i got me some 00 type r cams, can i run them with my stocks valve springs with out any problem... my ecu engages v tec at 6k and redlines to 10k... but i never take it past 8.5 with the type r cams, should i play it even safer and lower it or am i good?</TD></TR></TABLE>
Exhaust leak? no. Intake manifold leak, yes.
An exhaust leak would lead to a decrease in power and a subtle whistling noise (depending on how bad). Intake leak might make some noise too.
I wouldn't play with any of that **** without getting it tuned, professionally.
Old Apr 17, 2008 | 06:32 PM
immajackuup's Avatar
Default Re: would an exhaust leak cause me to bog??? (obuhmyuh)
yup get it tune or your motor will blow donkey dick
Old Apr 17, 2008 | 06:36 PM
unsungfate's Avatar
its tuned... with a hondata... i do believe i DO have a intake mani leak... gonna have to fix it and see if it helps
KoRE
Nov 2, 2009 06:59 AM
HFP-EP3
Dec 2, 2007 03:05 PM
EGgoJDM
Jul 7, 2007 08:42 AM
92integraVTECgsr
Mar 12, 2006 08:33 AM
94teggieGs-r
Sep 21, 2005 09:44 AM
