will zc v-tech pass smog???
Old Apr 17, 2008 | 12:04 PM
MUGEN_EG95's Avatar
Default will zc v-tech pass smog???
I just swapped in a zc v-tech single cam into my 95 civic ex last year and i was wondering if it will pass smog with no problem? The motor looks exactly like my d16z6! Any help would be nice.
Old Apr 17, 2008 | 12:23 PM
D16Y8-JDMYO's Avatar
Default Re: will zc v-tech pass smog??? (MUGEN_EG95)
If the smog tech actually decides to check it then it will fail.
If you find a place who can let you slide on visual then it'll be fine.
Old Apr 17, 2008 | 01:53 PM
24TEN's Avatar
PHANTOM MENACE
Default Re: will zc v-tech pass smog??? (D16Y8-JDMYO)
What's wrong with visual? What exactly would it fail for? It's listed as a legit motor replacement in the smog tech's handbook.
Old Apr 17, 2008 | 02:04 PM
thesmogman's Avatar
Default Re: will zc v-tech pass smog??? (24TEN)
OK, so you say it is OK to put a japan spec motor in an usdm car and it is listed in the handbook....Not. Why would they care about ecu's needing to be usdm then. The handbook states a replacement engine has to be offered in that model year in the US with either CA or Fed certification.
The ref is the only one to make this legal for us to smog. If it is not an USDM version no smog unless it has a BAR label.
Now You might be lucky and find a tech that is clueless on Honda's and he might just pass you.
Old Apr 17, 2008 | 02:08 PM
SuperSonikBluEK's Avatar
Default Re: will zc v-tech pass smog??? (thesmogman)
better cross your fingers and hope the tech doesnt know anythin!
Old Apr 17, 2008 | 02:22 PM
24TEN's Avatar
PHANTOM MENACE
That info came direct from the local referee from my area. He told me all that ZC stuff when I tried to obtain a BAR label for mine (which the ref said isn't necessary since the ZC is an equivalent motor as long as it's the same year as my car). And when I brought mine to a regular smog shop after that day, I told the guy to look it up and he said it was listed. So he smogged my car. Go figure.
In regards to the ECU, that is correct, you have to run it as the USDM equivalent (in this case a P28 for a D16Z6) which means the smog equipment has to be correct and matching per the original setup but the ZC itself is fine as is.
To be fair for this specific case, the OP said he swapped engines into an EX and didn't say he swapped ECUs or anything else.
Old Apr 17, 2008 | 02:30 PM
-JSpecEk*9-'s Avatar
i didnt know vtech phones needed smog
Old Apr 17, 2008 | 02:46 PM
obuhmyuh's Avatar
Default Re: will zc v-tech pass smog??? (-JSpecEk*9-)
I
<3
Old Apr 17, 2008 | 02:51 PM
d.a ryda's Avatar
Default Re: will zc v-tech pass smog??? (obuhmyuh)
vteK
Old Apr 17, 2008 | 03:57 PM
thesmogman's Avatar
One will say yes and one will say no. Ref's that is. You have to get the info from the one ref that is doing the testing. They are not all on the same page. And that is coming from my bar auditor.
Same with the smog tech's some might and some might not. I got to say the book is the final answer for me.
If it was me I would want a bar label so I don't have to worry about this same stuff the next time and the next etc...
Old Apr 17, 2008 | 04:02 PM
MUGEN_EG95's Avatar
ok thanks a lot guys i'll go to a smog station and see what they will say!
Old Apr 17, 2008 | 04:29 PM
d.a ryda's Avatar
i never heard of a motor havin v-tech whats that?
SoCalRacer
22
Aug 1, 2004 03:44 PM
Solidshady22
11
Apr 19, 2004 02:30 PM
drastikmeasurez
20
Feb 3, 2004 08:17 PM
The Alchemist...
14
Aug 10, 2002 03:20 PM
spy54
Dec 4, 2001 12:40 AM
