Power Steering leak from the steering rack
Old Apr 17, 2008 | 08:54 AM
doubleoazn03's Avatar
Default Power Steering leak from the steering rack
ive had this problem from a while back and my reseivoir is bone dry. all the fliuds leaked out from the the steering rack from where the boot is or was, i can tell because my boots been torn for a while. My girlfriends uncle said to just replace the rack for $100, hes a mechanic, but i was wondering, since i ran the power steering bone dry this long and not take it off the belt since i wasent using it, will the motor/compresor or whatever, go bad??? will it have to be replaced as well???
Old Apr 17, 2008 | 09:52 AM
JDM Lyfestyle's Avatar
Default Re: Power Steering leak from the steering rack (doubleoazn03)
why didnt you atleast keep adding more fluid every now and then?and how long has it been dry?
if your sure its been leaking from the rack then the seals are obviously gone in which case your best bet would be to simply replace it.
try pulling the belt off and spin the pump pulley while listening for noises.if you dont hear anything and it hasnt been making alot of noise then it may be ok.
Jon Petersen
Sep 13, 2018 08:07 PM
Hondaphile13
11
Jul 12, 2009 06:39 PM
busyychild
Feb 22, 2008 02:30 PM
PokePride
Apr 17, 2005 02:12 PM
yoshi234
Jan 7, 2002 09:19 PM
