issue with 1999 base model
Old Apr 17, 2008 | 07:18 AM
charlie0801's Avatar
Default issue with 1999 base model
I had the same thing happen last summer and never resolved it... seems to happen only when its warm/hot outside.
From a stop or low rpm, when i give it some gas it feels like its bogging... itl backfire 1 or more times and then go back to driving normally....
i have no idea what is causing this.
i changed cap/plugs/wires/rotor last summer and it was still doing it
also changed a o2 sensor at the same time
any input would be appreciated, thanks.
Old Apr 17, 2008 | 01:08 PM
AndyD's Avatar
Default Re: issue with 1999 base model (charlie0801)
Any mods?
What spark plugs are you using?
Old Apr 17, 2008 | 08:15 PM
only mod is a cone filter adapter
plugs are stock honda replacement
Old Apr 17, 2008 | 08:21 PM
5thGeneration's Avatar
Default Re: (charlie0801)
just throwin it out their as a possibility. fuel pump possibly...?
Old Apr 17, 2008 | 08:25 PM
if it were the fuel pump.... i would think it would do it at high rpm and not <2000
Old Apr 17, 2008 | 08:36 PM
gstrudler's Avatar
Does it happen when the car is cold, warm or either?
Old Apr 17, 2008 | 11:08 PM
borat's Avatar
Check/clean your IACV. You may also want to try cleaning the EGR ports, if you have a lot of miles on the engine.
Old Apr 18, 2008 | 03:15 AM
only happens when its warm outside and the engine is warm... the egr port was blocked off to try and stop this from happening... obviously i hasnt helped
Old Apr 18, 2008 | 05:54 AM
Si Speed's Avatar
Is it throwing a code? That might help narrow it down a lot...
Old Apr 18, 2008 | 08:15 AM
last summer it was throwing a code that stated system too rich or too lean (i think it was 43)
Old Apr 19, 2008 | 03:54 AM
turnofftheradio's Avatar
FPR? maybe? I'd at least test it to rule it out.
Old Apr 19, 2008 | 06:25 AM
how would i go about testing the FPR? and i cleaned the IACV last summer as well
Old Apr 20, 2008 | 05:50 AM
bump... more help needed and thanks to those who have stated their opinion
Old Apr 23, 2008 | 06:42 AM
help....
did a compression test the other day this is what came out 235-227-225-226
Old Apr 23, 2008 | 05:21 PM
gstrudler's Avatar
Those compression numbers are pretty decent and I wouldn't expect that to be the problem. If it's only happening when the engine is warm, then you can pretty much narrow it down to things that are temperature controlled. I'm not 100% sure, but could include things like FITV, IACV and EGR to name a few. If you haven't actually cleaned the EGR ports, that would be something to try and is cheap.
Old Apr 23, 2008 | 06:32 PM
to clean the egr, do i just dump some carb cleaner in the port and scrub? ive cleaned the iacv last summer with no change
Old Apr 23, 2008 | 08:26 PM
borat's Avatar
No, it's a whole lot more involved than that. Here's what I was talking about:
http://www.preludepower.com/fo...75440
Old Apr 24, 2008 | 03:15 AM
k seems lot more time consuming than cleaning the valve :S but i will see whay i can do.
thanks
AndreaMason
Oct 9, 2017 11:47 PM
Meraut
Jul 29, 2013 09:00 AM
wildman117
Feb 20, 2006 02:07 PM
kingpen
Aug 31, 2002 09:27 PM
buckfittyone
Jul 20, 2002 01:45 PM
