HELP
Old Apr 17, 2008 | 01:40 AM
adeline's Avatar
Default HELP
I need help my car will only let my give about 1/4 throttle and if I give it more it falls flat on its face. I little background it a 88 hf with a 90 dx motor and 90 si ecu, I have codes 6,7,9,10 right now show on my ecu. I am not shore but I dont think the 90 ecu is right for my cars set up.
Any help please
Old Apr 17, 2008 | 02:58 AM
~sp33~'s Avatar
EFB055
Have you checked your timing?
Old Apr 17, 2008 | 07:21 AM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: HELP (adeline)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adeline &raquo;</TD></TR><TR><TD CLASS="quote">I need help my car will only let my give about 1/4 throttle and if I give it more it falls flat on its face. I little background it a 88 hf with a 90 dx motor and 90 si ecu, I have codes 6,7,9,10 right now show on my ecu. I am not shore but I dont think the 90 ecu is right for my cars set up.
Any help please </TD></TR></TABLE>
If you still are running DPFI on the D15B2, then the PM6 ECU is not for you. If you did a MPFI conversion, check your wiring.
Old Apr 17, 2008 | 10:16 AM
adeline's Avatar
Default Re: HELP (wiZCo)
i will check the timing I am use a stock hf harness and one of my big question is the 90 si ecu any different the the 89 I use to ran with my last dx motor with a si intake manifold.
Modified by adeline at 2:14 PM 4/17/2008
Old Apr 18, 2008 | 01:23 AM
adeline's Avatar
any help at all
Anyone?!
Old Apr 18, 2008 | 06:52 AM
wiZCo's Avatar
Stouts 'n' Scotch
You're not making this easy for us because you're not being very clear as to what your setup is.
Let me get this straight: You're running a D15B2 motor with an HF harness and a PM6 ECU?
Have you done the full MPFI conversion or did you just slap a MPFI mani on there? Did you convert the HF harness correctly?
Old Apr 18, 2008 | 08:08 AM
th3pwn3r's Avatar
I recommend you take it to a shop or tear out that DX motor and drop a proper B16 or 18 setup in.
Old Apr 18, 2008 | 08:24 AM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: (th3pwn3r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by th3pwn3r &raquo;</TD></TR><TR><TD CLASS="quote">I recommend you take it to a shop or tear out that DX motor and drop a proper B16 or 18 setup in.</TD></TR></TABLE>
Wow, I can't even begin to tell you what's wrong with your "help". A B-series swap isn't necessarily always the best swap for everybody n00bert.
Old Apr 18, 2008 | 11:06 AM
adeline's Avatar
Default Re: (wiZCo)
why would have to charge and hf harness to mpfi? I put the si manifold on a d15 and yes I am running a 90 pm6. What is wrong with that?
The only things i change on thed 15 was the complete manifold and the distributor
what else do I need to change
Old Apr 18, 2008 | 05:13 PM
I heart My EF Sedan's Avatar
Default Re: (adeline)
looks like u didn't wire up the mpfi...
http://www.angelfire.com/d20/h....html
Old Apr 18, 2008 | 05:22 PM
zc89hatch's Avatar
your dx motor is only running 2 injectors and it dont match up with a si ecu because the si is four injector go buy a 0bd0 dx ecu then you wil be fine OR convert to mpfi with the si manifold
Old Apr 19, 2008 | 01:27 AM
adeline's Avatar
Default Re: (zc89hatch)
what are you guy not getting about running a hf harness that use 4 injector just like the si and I am use a si manifold on a dx motor. I know that the dx only runs 2 injectors, I have all three models of crx.
Old Apr 19, 2008 | 01:32 AM
adeline's Avatar
If I wanted a b-series swap then I would have already done one. I am just trying to keep it running well enough to get something else and then I am going to start a full restoration on my car.
If you think a b-series in so nice give me the money for one and I will spend it on something worth while.
Old Apr 19, 2008 | 07:31 AM
wiZCo's Avatar
Stouts 'n' Scotch
Well, based on your codes, I'm guessing you have the sensors hooked up wrong. Can you take pics of your IAT, Coolant temp sensor, and TPS or tell us the color of the wires running to each plug?
Also, which distributor are you using?
Old Apr 19, 2008 | 10:52 AM
adeline's Avatar
Default Re: (wiZCo)
i am using a hf or si distributor and is their any difference in the wiring in the engine bay of a 90 si then the 88-89
Old Apr 20, 2008 | 02:13 AM
adeline's Avatar
anymore help
Old Apr 20, 2008 | 08:17 AM
wiZCo's Avatar
Stouts 'n' Scotch
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adeline &raquo;</TD></TR><TR><TD CLASS="quote">i am using a hf or si distributor and is their any difference in the wiring in the engine bay of a 90 si then the 88-89 </TD></TR></TABLE>
No, but there are differences between the HF and other models.
Old Apr 20, 2008 | 10:57 AM
adeline's Avatar
Default Re: (wiZCo)
I just asking because I use the same wiring harness and everything on my last dx motor that I put in my hf and I didnt have this big of a problem
Old Apr 21, 2008 | 08:51 AM
zc89hatch's Avatar
CHECK YOUR GROUNDS tighten them up tight maybe your timing is off or maybe spark plug is not in correct
Old Apr 24, 2008 | 01:48 AM
adeline's Avatar
well I bought a new tps and now I have full throttle back but, my ecu will not reset. I tried pull the hazard and ecu fuse and ever pulled the ground form the battery, no matter what I try it still starts flash codes as soon as I turn the key.
Old Apr 24, 2008 | 04:43 AM
wiZCo's Avatar
Stouts 'n' Scotch
Maybe because the codes still need to be fixed? Is it running perfectly now or did you just get it out of limp mode?
Old Apr 24, 2008 | 12:33 PM
zc89hatch's Avatar
what distributor are you using
can u post pics of motor
Old Apr 25, 2008 | 03:32 AM
adeline's Avatar
it just got over the limp mode and i already stated what distributor I am using, what kind of engine shot do you need?
Old Apr 25, 2008 | 09:26 AM
wiZCo's Avatar
Stouts 'n' Scotch
Post pics of the IAT, CTS and TPS. They're all two-pin connectors, I'm guessing you connected them wrong at some point.
Old Apr 25, 2008 | 11:11 AM
adeline's Avatar
Default Re: (wiZCo)
I will take those when I have time working a lot and the tps in a three wire plug
EFcrxkidb
May 1, 2007 07:27 PM
FBPSidan
Apr 17, 2006 03:27 PM
1fst4
Jun 5, 2004 12:20 AM
onePOINTsix
Sep 9, 2003 08:17 PM
Kasper.
14
Aug 10, 2002 06:27 PM
