Suspension & Brakes Theory, alignment, spring rates....
Any tips on how to secure a rear endlink nut?
Old Apr 16, 2008 | 11:19 PM
EL-Driver's Avatar
Default Any tips on how to secure a rear endlink nut?
So I am running a JDM 23mm on my EK civic....
and using the correct endlinks...
none the less I have been noticing that these can really loose even after tightening them as much as possible..
so does anyone have anytips to keep the nut really secure?
One idea I had was wraping the endlink threads with plumbers tape...
Old Apr 17, 2008 | 03:34 AM
meb58's Avatar
Default Re: Any tips on how to secure a rear endlink nut? (EL-Driver)
They should have supplied nylock nuts. These are designed for fairly light torques specs while also remining in place - you shouldn't have to go thru this.
So, Red Locktite or - my preference, buy new nylock nuts that fit the application. Locktite will work, but removing the nuts won't be fun.
Old Apr 17, 2008 | 06:48 AM
gabebauman's Avatar
Default Re: Any tips on how to secure a rear endlink nut? (meb58)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by meb58 &raquo;</TD></TR><TR><TD CLASS="quote">New nylock nuts that fit the application.</TD></TR></TABLE>
Old Apr 17, 2008 | 07:54 AM
EL-Driver's Avatar
Default Re: Any tips on how to secure a rear endlink nut? (gabebauman)
Nylon locking nuts it is...
it was also a security mesaure from loosing the nut on the track..
would adding a washer be a good idea as well?
thanks for your help / I also posted this in the Road Racing / Autocross forum
Old Apr 17, 2008 | 05:27 PM
bildo16's Avatar
i would say just stick with the nylon locking nut for now, but if that fails, one of those springy washers and some thread locker and that nut will stay on.
akces
Sep 27, 2008 03:12 PM
t0ekn3e
May 18, 2005 07:17 PM
kingmonkey
Mar 15, 2005 07:11 PM
743power
13
Aug 26, 2003 06:53 PM
