Anyone know if B16a3 header is same length as B16a2?
Old Apr 16, 2008 | 08:47 PM
HatchSpeeD's Avatar
Default Anyone know if B16a3 header is same length as B16a2?
Here's my dilema. I have an obd-1 gsr motor in a 2000 civic ex coupe. It looks like it has the shorter gsr oem header on it with a modified stock integra catback exhaust. Problem is, there seems to be no o2 bungs in the header nor the cat & I'm running a p2t ecu which is obviously looking for the two o2's. I'm planning on keeping it obd-2 & need to pass inspection.
I have a stock header from my 94 Del Sol vtec (B16a3) lying around which does have the o2 bung in it. I figured if I found a stock 99-00 si exhaust including the cat, I can then hopefully bolt it all up. They don't have the same part numbers but does anyone know for sure if a B16a3 is the same length & same flange as a B16a2 (99-00 SI)
Thanks
Old Apr 17, 2008 | 05:39 PM
HatchSpeeD's Avatar
Yes, no?
talkJDM
Aug 11, 2011 05:56 AM
revhighmotorsports
Apr 11, 2004 08:19 PM
80884
Nov 27, 2003 06:05 AM
GripFactoR
Nov 19, 2002 08:28 PM
