Suspension & Brakes Theory, alignment, spring rates....
22mm rear sway bar w/ no front sway bar
Old Apr 16, 2008 | 06:30 PM
MrXclusivE's Avatar
Default 22mm rear sway bar w/ no front sway bar
I have a 98 hatch so it didn't come with any sway bars stock. I'm planning to install a mfactory rear sway bar soon, should I also get a front bar? or its going to be alright?
thanks
Old Apr 16, 2008 | 06:33 PM
TunerN00b's Avatar
Default Re: 22mm rear sway bar w/ no front sway bar (MrXclusivE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MrXclusivE &raquo;</TD></TR><TR><TD CLASS="quote">I have a 98 hatch so it didn't come with any sway bars stock. I'm planning to install a mfactory rear sway bar soon, should I also get a front bar? or its going to be alright?
thanks</TD></TR></TABLE>
It will be "alright", in terms of not causing dangerous problems or anything.
However, depending on your use of the car and desired handling behavior, a front bar may or may not be beneficial.
If you're just looking to reduce body roll on a street car, install the rear bar and see how it feels. If you still want less roll, consider a front bar, or increasing spring rates.
Old Apr 16, 2008 | 06:44 PM
MrXclusivE's Avatar
Default Re: 22mm rear sway bar w/ no front sway bar (TunerN00b)
Is it going to have crazy oversteer though? car is street/roadcoarse
Old Apr 16, 2008 | 07:36 PM
xsenceo89x's Avatar
your gunna spin lol.
too much oversteer imo. you might like it tho
Old Apr 16, 2008 | 08:13 PM
MrXclusivE's Avatar
Default Re: (xsenceo89x)
Lol! here I come auto-x!
Old Apr 17, 2008 | 03:30 AM
meb58's Avatar
Default Re: (MrXclusivE)
Every car and every driver is a little different. I think there is only one perfect setup for any given car on a given venue, but that written, give it a try. I drove a 1981 Ford Fiesta that had a rear bar only. The car went where is was pointed...meaning, it did what I asked it, exactly with zero stupid factor built in. The car required a lot of attention, but it rewarded attention. It would also spit on my grave the moment my concentration dropped. ...165hp and 1,750 lbs...it was a rip!
Try it, and test it carefully, especially on public roads.
Old Apr 17, 2008 | 06:53 AM
gabebauman's Avatar
Default Re: (meb58)
My 98 Civic Ex Coupe feels very neutral & nimble with the stock 22mm front sway bar and 22mm rear ITR sway bar. I'm also on Koni Yellows with custom rate Ground Controls, (450f/400r).
SpoonKid
Oct 26, 2006 11:05 AM
EJ1 wilcox
Suspension & Brakes
23
Mar 14, 2006 12:49 PM
TegoDC5
Suspension & Brakes
14
Sep 13, 2005 08:45 AM
Andrew 825SM
Jul 7, 2003 01:19 PM
bw54867
Oct 14, 2002 06:51 PM
