Replacing Brake Master Cylinder?
Are you looking to replace the brake booster too or just the master cylinder?
The master cylinder is very straight forward.
-Using a 10mm Flare wrench remove the brake lines from the master cylinder
-Remove the 2 12mm bolts holding the master cylinder to the brake booster
-Reverse process with new master cylinder
-Bleed brakes
-Bleed brakes
mixmastabob
Dec 7, 2006 12:09 PM
integra123
Aug 8, 2006 05:52 PM
