no parking lights?
Old Apr 16, 2008 | 07:39 AM
All-Motor-Junkie's Avatar
Default no parking lights? *UPDATE w/ PIC*
Thanks for all the help! was in wiring hell cause of a DIY from previous owner.
parking lights woot ! thanks for everyone who helped!
Modified by All-Motor-Junkie at 7:19 AM 4/25/2008
Old Apr 16, 2008 | 07:44 AM
cmwright1986's Avatar
check the "small light" fuse under the hood. its the one that controls the dash lights and the parking lights
Old Apr 17, 2008 | 06:00 AM
my dash lights work though so if that fuse was blown wouldent my dash lights go out?
Old Apr 18, 2008 | 05:59 AM
bump like stated before fuse isent blown, brings me to my original question..
is the 93 and 94 dash harness wired differently when it comes to the parking lights?
Old Apr 18, 2008 | 07:08 AM
sean1121's Avatar
Default Re: (All-Motor-Junkie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by All-Motor-Junkie &raquo;</TD></TR><TR><TD CLASS="quote">is the 93 and 94 dash harness wired differently when it comes to the parking lights?</TD></TR></TABLE>
No. Check all your fuses, both under hood and under dash.
Did you disconnect the battery when you installed the EL's?
Old Apr 18, 2008 | 08:08 AM
Default Re: (sean1121)
always disconnect battery when doing any electrical why? all fuses are good.
Old Apr 18, 2008 | 02:16 PM
bump!
Old Apr 19, 2008 | 08:41 AM
bump! would like this fixed thanks...
Old Apr 19, 2008 | 01:21 PM
ttt
Old Apr 19, 2008 | 02:07 PM
mgags7's Avatar
Sounds like you simply didn't hook something up.
I'd check the huge 30 (or so) pin connector to the underdash fuse box, it has the wires for the parking lights. I had a problem like this once and it was due to a bad pin/contact in there.
Old Apr 19, 2008 | 02:17 PM
all are hooked up, good idea though maybe one isent all the way in thanks!
Old Apr 19, 2008 | 02:20 PM
98vtec's Avatar
moderator emeritus
i dont know the answer to your problem, but you disconnect the battery so there is no current going through the electrical system. So if two bare wires touch, nothing with blow up.
Old Apr 23, 2008 | 06:11 AM
^^ ya i know thats why i disconnect the powet every time i do electrical, anyways i took mgags advice and found this wire, assuming this may be the problem lmao!
anyone got the diagram for this? where does this wire go looks like a simple splice & heatshrink, thanks!
Old Apr 23, 2008 | 07:28 AM
bump!
Old Apr 23, 2008 | 08:28 AM
come on guys bump!
Old Apr 23, 2008 | 10:28 AM
wow no one?
Old Apr 23, 2008 | 07:41 PM
gotjnco's Avatar
dont worry man... im looking through my helm's manual and to see what is that wire for...
Old Apr 23, 2008 | 08:21 PM
gotjnco's Avatar
Default Re: (gotjnco)
hey dude... that wire is from the plug for your COMBINATION LIGHT SWITCH!!!!
Old Apr 23, 2008 | 08:41 PM
gotjnco's Avatar
Modified by gotjnco at 9:53 PM 4/23/2008
Old Apr 24, 2008 | 11:09 AM
gotjnco's Avatar
Default Re: no parking lights? *UPDATE w/ PIC* (All-Motor-Junkie)
bump
Old Apr 25, 2008 | 06:33 AM
bump fixed, thanks again!
Old Apr 25, 2008 | 07:30 AM
gotjnco's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by All-Motor-Junkie &raquo;</TD></TR><TR><TD CLASS="quote">bump fixed, thanks again!</TD></TR></TABLE>
I'm glad it got fixed
distra
Apr 20, 2017 11:32 PM
ltec
Feb 13, 2013 05:17 PM
peachykeenwight
Apr 12, 2007 04:52 PM
KaoticSnow
Jan 25, 2007 09:52 AM
xxx
Oct 31, 2005 06:57 PM
