Suspension & Brakes Theory, alignment, spring rates....
power steering fluid leaking please help
Old Apr 16, 2008 | 05:48 AM
vnteg's Avatar
Default power steering fluid leaking please help
i have 1999 integra , when i look at the rack i think it leaking from hose between the rack, NOT the high pressure, the hose that was on the rack
is it possible that leak from?????how to fix please advice?? thank
Old Apr 16, 2008 | 07:54 PM
Targa250R's Avatar
be professional
Default Re: power steering fluid leaking please help (vnteg)
http://www.acuraautomotivepart...1.gif
Number 19 or 20 I assume?
If it has threaded fittings on each end and is sold separately, it can be replaced. Use a flare nut wrench to avoid rounding them off.
You should probably go to the local Acura dealer and have them order the line for you.
AccordEX1991
Honda Civic (2001 - 2005)
Feb 21, 2016 12:13 PM
erikiksaz1
Sep 30, 2011 01:25 AM
pityocamptes
Feb 26, 2011 07:41 AM
AcuraTilIDie
Mar 18, 2008 08:20 PM
94c1v1cex
May 21, 2007 05:03 PM
