How to remove seatbelt
Old Apr 15, 2008 | 11:06 PM
kelviiv's Avatar
Default How to remove seatbelt
Hello
I would really appreciate it if you guys can help me swap the rest of my interior.
I recently purchased a new db8 with tan interior and am swapping it with all black.
I have done all the seats and center console, carpet, etc.
All i have left is the E-brake & Seatbelt
I already took the bottom of the seatbelt off, I just dont know how to take the top part off where it can slide, As for as the e-brake goes. I just do not know where to start. i do not want to take off unnecessary parts.
Old Apr 15, 2008 | 11:25 PM
BlueIntegraBoy's Avatar
Default Re: How to remove seatbelt (kelviiv)
Remove the armrest. Then remove the ebrake cables from the handle. Unplug the ebrake sensor. Unbolt the #16 bolts.
Remove the covers on top of the seatbelt, then remove the large bolt. Take off the panel to remove the bolt for the retractor thing.
Old Apr 15, 2008 | 11:31 PM
kelviiv's Avatar
^ Thanks
1 more, The door handles inside the car, I already swapped the pannels to black, I know I have to take it off but right now it has black door pannels with tan door handles inside the car, How do i swap this out/ take it out?
Old Apr 15, 2008 | 11:35 PM
Default Re: (kelviiv)
You need to swap the whole handle/lock assembly (#10/30). It unscrews and undo the handle from the door rod.
Old Apr 15, 2008 | 11:50 PM
kelviiv's Avatar
Ok just to clarify, for the door I would have to swap the whole thing which would mean the outside handle too?
My new car is green and my old car is black, that would mean I would have a black handle on the outside and the inside on a green car correct?
Are there anyways I can just swap the handles after I take it off or no?
Old Apr 16, 2008 | 12:06 AM
I thought you are swapping for black interior. You can leave the outside handles, but just change the inside handles.
Old Apr 16, 2008 | 12:09 AM
kelviiv's Avatar
yes i need to change the inside handles only
haha i thought you meant i would have to change the handle for the outside + inside, so if i wanted to change the inside what exactly would i take off?
Old Apr 16, 2008 | 12:12 AM
The screws holding in the #10/30 (diagram above) assemblies, then remove the door rod from those assemblies.
Old Apr 18, 2008 | 11:25 AM
kelviiv's Avatar
sorry to bring this back but can you post the link on how to remove the seatbelt on the back of a 4 dr integra
Old Apr 18, 2008 | 12:20 PM
albertoG87's Avatar
I think you have to take some of the interior panels off, and once that is done you can clearly see the seatbelt assembly, and just unbolt and replace..
mpxs20
Jul 18, 2005 06:07 PM
Cuong-nutz
Feb 25, 2005 12:13 PM
Siegfried
Mar 29, 2004 03:54 PM
. o 69 o .
Apr 15, 2003 08:36 PM
allmotorls95
Jan 14, 2003 10:15 AM
