were to put manual trans fluid??
Old Apr 15, 2008 | 08:56 PM
pnoipj89's Avatar
Default were to put manual trans fluid??
can anyone help me out? im doin a swap and seem to have forgotten were it pour in the manual trans fluids at? i dont want to put it in a spot to were its not suppose to be at? thanks
Old Apr 15, 2008 | 09:10 PM
Rikter's Avatar
Put it in the transmission?
Ok. Some help would be what kind of vehicle are you working on?
Honda trans have two bolts on the side. One is the lower, one is the higher. The lower is for getting the fluid out, the higher one is for putting the fluid in. You should be able to see if it you jack up the car a bit and take a look from the passenger side/underneath. Most people will make a bottle and a hose into a drain system and go in from the engine bay to get the fluid in.
Good luck.
-Rik
Old Apr 15, 2008 | 09:18 PM
SuckMyDOHC's Avatar
Default Re: (Rikter)
As posted above, theres two bolts. You need a 3/8 ratchet to remove them.
Old Apr 15, 2008 | 10:06 PM
super jdm yo's Avatar
Default Re: (SuckMyDOHC)
isn't the top one a 17mm and just the bottom a 3/8 ratchet?
Old Apr 16, 2008 | 05:43 AM
posHonda's Avatar
I fill in through the VSS but alot of people advise against that since theres no real way of measuring that way unless you have the fill bolt open and it starts to leak. Im pretty sure its somewhere around 3.2qts.
Nicholas Bailey
Transmission & Drivetrain
May 23, 2016 09:11 PM
bristolhonda
Jul 31, 2014 09:37 AM
jmanuel
Apr 24, 2014 09:48 PM
Cypher0117
May 3, 2005 06:47 PM
Re3irth
12
Sep 1, 2004 02:58 PM
