telescoping gauge??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00b18b »</TD></TR><TR><TD CLASS="quote">yep I don't see why not. I used a inside mic and used a outside mic to measure it. just take many measurements to compare your numbers.</TD></TR></TABLE>
so i can say forget the expensive 200-300 dollasr dial bore gauge?
bore gauges are sweet if you're going to be building engines quite often get that over the telescoping gauge. its much easier to use , but if $ is tight decide on whats going to suit your needs.
Topdawgg
Jul 3, 2006 01:11 PM
