Audio stuff FS: Xtant mono amp and rockford fosgate p2 12" sub
Old Apr 15, 2008 | 07:29 PM
fliplyricist1's Avatar
Default Audio stuff FS: Xtant mono amp and rockford fosgate p2 12" sub
As title states, selling this audio stuff as I had to go a different route for my application.
Amp is HIGH QUALITY xtant a3001 monoblock amp, perfect for one or two subs. Rated at
150watts x1 @4ohms
or
300watts x1 @2ohms
WAY underrated power too. In fact, I wired it up for
600watts x1 @1ohms for about an hour straight with no issues whatsoever.
Has built-in 24 octave butterworth crossover, bass boost @45hz, and balanced line inputs.
This amp is ready to get it done. Sound quality > pretty looks. Casing has quite a few imperfections since this is an older amp, but I garauntee it works 100 percent just like new. Includes original box and manual.
Selling for 110 bucks shipped via USPS Priority OBO
Next up is a Rockford Fosgate p2 d212 12" Dual voice coil subwoofer with dual 2ohm voice coils. This is the new model, not the old one. This thing does slam with the right wattage, and hit pretty hard with the above Xtant amp, not even pushed hard. Sub is gem mint and only installed in a sealed box and tested for about an hour. No nicks, no imperfections...just like new. Includes original box with mounting trim plate and instructions.
Specs are as follows:
500 watts per sub
RMS: 250 watts per sub
Impedance: Dual 2 ohms
Venturi-effect center pole dispersion venting/cooling system
High modules closed conical polypropylene cone and ABS/Acrylic dustcap assembly geometry
Tear and Fatigue resistant poly-cotton spider
High density compressed half-roll sealed poly-foam surround
High temperature voice coil with spun-laced Nomex insulating re-inforcment collar
Optimized motor magnetics with extended pole and bumped backplate
Double stacked ferrite magnet structure
Multi-point high temperature/high strength neck joint bonding technique
Semi-flexible PVC removable protective motor cover
Custom insulated/isolated compression input terminal assembly
Diamond cut cast aluminum motor cover for improved heat dissipation
Proprietary spider venting/cooling technique
Frequency Response: 26 Hz - 250 Hz
Sensitivity: 86 dB
Free-air-Resonance: 26 Hz
Mounting depth: 6-3/8"
2" 4-layer Voice Coil
Sealed Box Volume: 0.7 - 1.8 cubic ft.
Ported Box Volume: 1.79 cubic ft.
1 Year Autosounds4less Warranty
However, this sub can handle well over 250 watts rms. Great sq sub, works well in both sealed and ported enclosures.
Just looking to get back what I spent. 100 bucks shipped OBO
I will have pics of items up tomorrow. Payments to be made via paypal....I always ship lightning fast!
Thanks for looking
Nader_D
Audio / Security / Video
Jan 23, 2003 09:50 PM
