Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Coilover question: PIC vs. Koni/GC on an ef
Old Apr 15, 2008 | 07:12 PM
SlowB16's Avatar
Default Coilover question: PIC vs. Koni/GC on an ef
I am trying to figure out what coilover setup I should go with. My car is an ef hatch with a b16 in it, and will be used for daily driving and HPDE events.
I was pretty set on going with the GC/Koni setup with front top hats with 500f/600r spring rates. However, after doing a little reading and talking with some friends it sounds like the PIC Select or Apex setup might be a better option. The Select's are adjustable and the Apex's aren't, but the Apex's are a lot cheaper. Another factor is that the PIC's don't offer a stiffer rate in the back.
I would appreciate your opinions. Thanks
Old Apr 15, 2008 | 07:22 PM
PIC Performance's Avatar
Default Re: Coilover question: PIC vs. Koni/GC on an ef (SlowB16)
We do offer setups that have a higher rear spring rate than the front, those are the R-series of coilovers. EF's have the R2's, which are 10k/14k which have been run with great success in Honda Challenge 4 in the midwest by Sam Myers.
Old Apr 15, 2008 | 08:38 PM
SlowB16's Avatar
Default Re: Coilover question: PIC vs. Koni/GC on an ef (PIC Performance)
I think that would probably be a bit much for me!
Old Apr 15, 2008 | 10:03 PM
liam821's Avatar
25 Year Member
I was in the same situation as you, however i ended up with GC/Bilsteins. Picked Bilsteins because they are just down the street from me, so getting revalves are quick and easy.
But for the money, i think PIC makes a quality product but i think you will be very happy with either setup.
Make sure you search through the archives too, there are tons of threads about GC vs PIC. Lots of great information about both products.
My GC with revalved Bilsteins and GC tophats.
Old Apr 16, 2008 | 12:41 AM
1net's Avatar
Hi,
I'm in almost the same situation and I too am starting to get inclined towards something other than GC+Koni.
I know a lot of people are very happy with koni, and I've been driving my set for about 3 years now, but there's something strange about their valving. I'm not an expert, but I've tried the yellows with soft and stiff springs and something seems a bit wrong.
Just recently, I tried a different brand (Buddy Club RSD) on a friend's car. I will not go into detail, but I'm still amazed of the amounts of traction. For now, they seem to be my #1 choice, but....
I found PIC and I'm stunned by the similarities ( in appearance ) between them and the BC. I also see that people are happy with PIC and that got me thinking that PIC may be my best choice. PIC is definitely cheaper, but for me personally, I decided to not be a cheep *** this time and I want to buy the better coilovers not the better bang for the buck.
so SlowB16, I personally would advise you against GC simply because koni may be the best shock for the buck, but it's not THE BEST SHOCK.
Here are some specific questions:
1. Is there anyone here who has driven on PIC, BC RSD, BC N+ and is willing to advise us?
2. Are BC offered with different spring rates
3. Can I switch front and back springs with PIC and BC ( i mean buy a 10k/12k and switch them to 12/10) or in yet more words: what range would the PIC/BC shocks handle.
4. one more for those who have tried both brands. I was amazed how BC RSD can be pretty comfortable and still perform great on the track. Can I expect the same from PIC select?
Thanks in advance
Old Apr 16, 2008 | 05:19 AM
Hayasa15's Avatar
well koni/gc seems to be the setup atleast in the sts class. so i would like to see what other people think about this.
Old Apr 16, 2008 | 07:08 AM
Lo-Buck EF's Avatar
Default Re: (Hayasa15)
PIC>OTS Koni/GC
pimp koni> PIC
since ur looking for something that wont break the bank, pic is probably better for you. they are already good on front travel (which is an issue on the ef chassis) and have good dyno numbers compared to ots koni (at keast the r2s that i looked into did)
Old Apr 16, 2008 | 08:44 AM
vbspec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hayasa15 &raquo;</TD></TR><TR><TD CLASS="quote">well koni/gc seems to be the setup atleast in the sts class. so i would like to see what other people think about this.</TD></TR></TABLE>
Its not an off the shelf Koni shock thought. The standard now is and has been the SPSS3 valved shocks . These can be purchased new as their "Race" shocks or OTS shocks can be sent back shortened and revalved.
Old Apr 16, 2008 | 12:10 PM
SlowB16's Avatar
Default Re: (vbspec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lo-Buck EF &raquo;</TD></TR><TR><TD CLASS="quote">PIC&gt;OTS Koni/GC
pimp koni&gt; PIC</TD></TR></TABLE>
That is kind of what I was thinking
Old Apr 16, 2008 | 01:08 PM
STN_Pat's Avatar
Default Re: (SlowB16)
i always wanted to change my suspension year after year until i had konis.
i would not get anything else than koni or bilstein when on a budget...
Old Apr 16, 2008 | 02:00 PM
vietnameeh's Avatar
I been thining about giving them a try on the race car
with money low these days, and the suspension needs to be revalved and redone. next year i maybe pick a set up from PIC (maybe theyll offer a SCCA discount ) if i somehow dont get money to get race konis and another set of springs. also thats if i still have this car
Old Apr 18, 2008 | 08:11 AM
Lo-Buck EF's Avatar
i just had my buddyclubs on track for the first time with the new rebuild. i think i need some more rear spring, but other than that they work good.
Old Apr 18, 2008 | 09:48 AM
Stefndogg's Avatar
Default Re: (Lo-Buck EF)
I love my PIC's(Select p3's...12kf/10kr)....
i used to have Ground Controls and kyb agx's and they were pretty good too(obviously the koni's are much better than the agx's and i had ots rates which were pretty soft)....and i have driven a couple hondas with the GC/Koni setup and it feels great..
The PIC's are awesome...i have had them for about 10 months and they are holding up great...i live in downtown sf(where every street has 1foot deep potholes), and even after driving around for 10months of abuse they have not failed me once...heres some pictures from a recent track day (redline time attack)
I want to thank PIC for their excellent customer service too(i wnt to order their apex coilovers and they were out of stock, so they hooked me up with a great price on the selects instead..which were what i really wanted but couldn't quite afford)...i really felt like they were going above and beyond to make sure i was happy...props
Old Apr 18, 2008 | 12:39 PM
mlrmotorsports's Avatar
Default Re: (Stefndogg)
PIC
Old Jan 21, 2010 | 07:13 PM
Eydreeyun's Avatar
Can u ride dump with pic slects and let's say ur moderately lowered on 12kf 10kr how's the ride? Bouncy? Or does it feel like your on ots gc/koni?
Old Jan 21, 2010 | 07:37 PM
ncwlau's Avatar
Is this the last post before the lock?
Old Jan 21, 2010 | 09:46 PM
Stinkycheezmonky's Avatar
Suspetise...
It sure is! Lucky you, Nick!
tooslohatch
Suspension & Brakes
May 6, 2013 10:47 PM
roadrunner_2k2
Suspension & Brakes
Apr 27, 2012 08:36 PM
BrowNKiD
Suspension & Brakes
Feb 4, 2011 12:10 PM
EFM_ookie
Suspension & Brakes
Mar 1, 2007 12:52 PM
