Suspension & Brakes Theory, alignment, spring rates....
GroundControl | Top Hats | Camberplate | Questions | 06' RSX
Old Apr 15, 2008 | 01:13 PM
djtrust121's Avatar
Default GroundControl | Top Hats | Camberplate | Questions | 06' RSX
what's up guys. I currently bought new suspension setup for my 06' RSX type S. I got the Ground Control Coilovers, along with the Koni Yellow setup. My question is, do I really need the top hat/ front camber plate for this setup. Ground Control discontinued making the top hat and front camber plate for the RSX. Now, I want to do the setup right. I orginally wanted to buy it with the setup, but can't because GC doesnt make them anymore for my car.
If I don't have it installed, will it hurt my car in anyway? Also, on my last setup.. I had issues with a heavy knocking sound when I turn my wheel, due to a poor top hat.
Also, the company I bought the new setup from said I could use my stock OEM top hat. What do you guys think?
People with this setup.. give me feed back on the setup: likes, dislikes, etc... (I know I could have done a search for this question, but I might as well throw in in here).
Thanks in advance Honda-tech! Any help and feedback would be great!
Old Apr 15, 2008 | 08:58 PM
djtrust121's Avatar
Default Re: GroundControl | Top Hats | Camberplate | Questions | 06' RSX (djtrust121)
BUMP! anyone?!
Old Apr 16, 2008 | 06:54 AM
djtrust121's Avatar
Morning Bump...
Old Apr 16, 2008 | 07:41 PM
Targa250R's Avatar
be professional
I don't even see a point of modding suspension on a McPherson strut car if you aren't going to use camber plates. Not being able to adjust the camber sort of defeats the purpose, unless you absolutely don't care about the handling and are just after the look . . .
Mac strut suspension is severely camber-challenged and needs a significant amount of static negative camber to work well.
Old Apr 16, 2008 | 08:27 PM
djtrust121's Avatar
Default Re: GroundControl | Top Hats | Camberplate | Questions | 06' RSX (Targa250R)
I see. thanks for the input. Are there any other after market camber plates i can get for this specific setup. I sure hope this this setup works out for me. Im going to do more research to see how others run this setup on the same car.
Old Apr 16, 2008 | 08:42 PM
djtrust121's Avatar
should I buy this:
http://www.clubrsx.com/cr/SPC-...nsion
Old Apr 16, 2008 | 09:20 PM
Targa250R's Avatar
be professional
Crash bolts? You could try those. Not ideal, but better than nothing.
Looks like only Hotchkis and K-Mac make separate universal camber plates for the RSX from what I can see, now that the GCs are discontinued. The only other options would be to mod something like the K-sport camber plates to somehow work with the Koni inserts, mod a camber plate from a different car, or have something custom fabricated. What a hateful selection.
Old Apr 16, 2008 | 09:34 PM
djtrust121's Avatar
oh ok cool. imma try doin the setup with out the front camber plate/ kit. and exam how it goes... if i really need one then ill look at my options from there.. i hope I can pull it off with out a camber kit/ plate. There are a few RSX's on board that are running the same set-up im going with.. so hopefully I'll have the same luck as them..
thanks again ...
Old Apr 18, 2008 | 06:31 AM
Hayasa15's Avatar
i have the Hotchkis plates on my 02 civic. Simple design and it has worked great for me. The car is a daily driver and the camber has not slipped at all only problem is they squeak but i was expecting creaking noises since i lowered it.
Old Apr 18, 2008 | 07:12 AM
djtrust121's Avatar
Default Re: (Hayasa15)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hayasa15 &raquo;</TD></TR><TR><TD CLASS="quote">i have the Hotchkis plates on my 02 civic. Simple design and it has worked great for me. The car is a daily driver and the camber has not slipped at all only problem is they squeak but i was expecting creaking noises since i lowered it.</TD></TR></TABLE>
would you happen to know if Hotchkis makes plates for my ride (06 rsx-s). Any websites or links you can refer me to? Imma bust a search on Hotchkis plates now. thanks!!
Old Apr 18, 2008 | 07:27 AM
djtrust121's Avatar
Default Re: (djtrust121)
does anyone know if the Tien camber plates will work together with the ground control/ koni yellow setup??!
thanks in advance.
Old Apr 18, 2008 | 06:50 PM
Hayasa15's Avatar
well i am pretty sure my camber plates are for the rsx. so i would start with the hotchkis site if they still make em
Old Apr 21, 2008 | 10:28 AM
djtrust121's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hayasa15 &raquo;</TD></TR><TR><TD CLASS="quote">well i am pretty sure my camber plates are for the rsx. so i would start with the hotchkis site if they still make em</TD></TR></TABLE>
thanks..
imma try it w/o amber adjustments up front.. hopefully i can pull it off.. i have a rear camber kit... i heard that was the most important..
thanks again.
Old May 4, 2008 | 04:51 PM
djtrust121's Avatar
So I installed my ground control/ koni yellow setup. Im having issues with a knocking noise in the front of my car. The noise seems to be that the GC/Koni set up is having problems working with my stock top hat. The top hat hits body when i go over bumps etc... The sound is real annoying. Has anyone had this problem? If so, Pls assist. Im trying to look for an after market top hat, but no luck! GC discontinued the top hats/ camber plates for my car. So I cant find one that will work with my set up.
Thank in Advance.!
Old May 4, 2008 | 05:38 PM
djtrust121's Avatar
will this work with the GC/ Koni setup?
http://store.titanmotorsports.....html
Old May 4, 2008 | 09:53 PM
djtrust121's Avatar
bump...
Old May 5, 2008 | 03:59 AM
djtrust121's Avatar
bump.. anyone?
Old May 5, 2008 | 09:12 AM
djtrust121's Avatar
does anyone have a pic or diagram on how the GC/Koni looks assembled? I want to make sure is assembled right. I tried to do a search and got nothing.
thanks
Old May 5, 2008 | 11:50 AM
djtrust121's Avatar
bump!
Old May 5, 2008 | 03:47 PM
TunerN00b's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djtrust121 &raquo;</TD></TR><TR><TD CLASS="quote">So I installed my ground control/ koni yellow setup. Im having issues with a knocking noise in the front of my car. The noise seems to be that the GC/Koni set up is having problems working with my stock top hat. The top hat hits body when i go over bumps etc... </TD></TR></TABLE>
Um, the top hat should be solidly mounted to the body.
Now, if the strut body is hitting the top hat (completely compressing the shock shaft), then you're radically undersprung for your ride height and possibly forgot to install the bumpstops.
(Or I'm completely off base here. I haven't exactly looked at strut based Honda suspensions much.)
Old May 5, 2008 | 04:08 PM
djtrust121's Avatar
Default Re: (TunerN00b)
ok here are some pics i took of my current situation. I may have found the problem, let me know what you guys think.
Pic 1: (full setup pic):
Pic 2: (What I think the problem might be.)
** I'm not sure if i need that black metal piece, as it moves around loosely. That piece came from my stock setup. I'm thinking I may need to remove that, since it really serves no purpose, or so I think.
Pic 3: (By removing the black piece, the gold ring should sit firmly with in the silver one right? thus, not needing that black piece?)
Pic 4: (the very top part of the setup.)
So im thinking i dont need that black metal piece, and that might be whats causing the sounds.? Let me know what you guys think. Do i need any rubber pieces or am i missing anything?
Thanks for everyone's input as well! Its helping me narrow down a solution for my problem.
Modified by djtrust121 at 5:18 PM 5/5/2008
Modified by djtrust121 at 5:20 PM 5/5/2008
Modified by djtrust121 at 5:21 PM 5/5/2008
Old May 6, 2008 | 12:18 AM
slammed_93_hatch's Avatar
that black piece was doing(for the stock spring) what the gold piece is doing for the eibach spring
Old May 6, 2008 | 04:04 AM
djtrust121's Avatar
Default Re: (slammed_93_hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slammed_93_hatch &raquo;</TD></TR><TR><TD CLASS="quote">that black piece was doing(for the stock spring) what the gold piece is doing for the eibach spring</TD></TR></TABLE>
Which means I dont need that black piece huh?
thanks.
Old May 6, 2008 | 12:04 PM
djtrust121's Avatar
afternoon bump.
Old May 7, 2008 | 07:19 AM
djtrust121's Avatar
bump.
