Bleeding front brakes only?
Old Apr 15, 2008 | 01:03 PM
smoovekriminal's Avatar
Default Bleeding front brakes only?
I looked in the FAQ on how to bleed brakes but no answer for my question. Now I just recently changed my front rotors and brake pads and now my brakes are kinda mushy..i know i have to bleed them but can i get away with just bleeding the front only?
P.S. I have a 94 ls...
Old Apr 15, 2008 | 03:26 PM
Blahblah718293's Avatar
Default Re: Bleeding front brakes only? (smoovekriminal)
just do em all... its not like it takes all day. and for changing pads and rotors, you dont need to open the line. if you didnt open the line, then your problem lies elsewhere.
Old Apr 15, 2008 | 04:35 PM
kicksremix2o6's Avatar
i dont even think you can just do the front cause the fluid is connected to all four brakes lines so just do them all if you attempt to do the front only then you could have air bubbles in your lines.
Old Apr 15, 2008 | 06:11 PM
non-VTEC's Avatar
make sure none of the slide pins or caliper pistons are seized. that can cause a soft pedal.
Kendo88
Mar 10, 2009 09:57 PM
t0kyoStatus
Dec 28, 2008 10:34 PM
Jizzmaster Zero
17
Mar 3, 2007 10:04 PM
Groove_D
Jul 3, 2004 01:28 PM
integrakilla
12
May 5, 2004 05:08 AM
