Rewiring front turn signals to the outside HELP.
Old Jul 11, 2002 | 01:24 PM
TypeR-R6's Avatar
Default Rewiring front turn signals to the outside HELP.
Yes I did a search. A while back there was a white Type R that had rewired the front corner lenses so the turn signal is on the out side rather than the inside. I can't find that post and I am interested in doing this. Does anyone know which post it was on or know how to do it?
Old Jul 11, 2002 | 01:30 PM
AssPenny's Avatar
Default Re: Rewiring front turn signals to the outside HELP. (TypeR-R6)
Just cut the wires and swap the ends.
Old Jul 11, 2002 | 01:32 PM
reefer_bob's Avatar
Default Re: Rewiring front turn signals to the outside HELP. (AssPenny)
Nice simple solution there Craig. Sounds about like a 4 beer job to me... one per light bulb...
Old Jul 11, 2002 | 01:34 PM
AssPenny's Avatar
Default Re: Rewiring front turn signals to the outside HELP. (reefer_bob)
Actually its a 6 pack. 1 before starting, 1 for each bulb, and one when you're finished and admiring your work.
Craig - Who is an expert at proper beer drinking time.
TypeR-R6's Avatar
yeah I thought of that but for some reason I remember it involving a little more than that. Will the small bulb handle it? I know there was a post on it I just can't find it.
Old Jul 11, 2002 | 01:37 PM
AssPenny's Avatar
Check the bulbs and see what amp they run at. If they are the same then great, other wise, just soilder in the correct resistor when you change the ends.
Old Jul 11, 2002 | 01:48 PM
sgT's Avatar
sgT
pre 98 integras the outer bulb is a turn signal as well.
Its incredibly easy to wire the side bulb to blink with the front.
Take the negative lead off of the side bulb and tap it to the lead for the
front blinker. Result: side will come on with the parking lights and blink
with the turn signal.
Old Jul 11, 2002 | 02:20 PM
uNF$@#!'s Avatar
Default Re: Rewiring front turn signals to the outside HELP. (sgT)
...the side bulb is a single filament... do you mean the bulb would turn off when the signal is on? .... yeah, im guessing this is what you mean since it would make sense to me this way...
Old Jul 11, 2002 | 02:32 PM
reefer_bob's Avatar
My bad. I assumed that the Pre-Beer and Post-Beer were expected and were never in question.
Old Jul 11, 2002 | 03:01 PM
Fuminsho's Avatar
Default Re: Rewiring front turn signals to the outside HELP. (Soup ****)
check the bulb out... even though they don't have it wired to blink any more they still us a dual filament bulb...
Story:
When I switch from my 97 GSR to my 2000 integra something or other.. I thought that it was broken, because it didn't blink like my '97 So I took out one of the bulbs to see what's up... I also had the old '97 factory bulbs and they were the same part number and you could see that it has two elements.
I called the dealership and asked if all I needed to do was change the current relay to the older one to make it work or if I had to add one.... They couldn't answer my question. So I still don't know, but I'm sure someone with time could look at the wiring diagram in a chilton and see if it can be done...
any one?
Old Jul 11, 2002 | 03:10 PM
TypeR-R6's Avatar
Default Re: Rewiring front turn signals to the outside HELP. (Fuminsho)
Here is the problem. I put PIAA super white bulbs in the clear corner lenses and the outside bulb lense is clear while the turn signal side is shady so when the lights are on you can tell the difference between the bulbs. I saw a white type R on this board that only had the outside bulbs hooked up. It made the front end look wider since he only had the outside bulb hooked up.
Old Jul 11, 2002 | 03:11 PM
sgT's Avatar
sgT
On alll 94+ integra models the front are dual filament and the sides are single.
Just on 98+ the side do not turn off when the front signal blinks.
If you just want the sides to blink do what i said before and remove the front bulb
Old Jul 11, 2002 | 05:19 PM
TypeR-R6's Avatar
I don't want the front bulb to blink I want the single filament side bulb to be used as the turn signal.
Old Jul 11, 2002 | 06:08 PM
sgT's Avatar
sgT
i know. thats why i already told you what to do. Read carefully.
MDAMP2005
Oct 31, 2018 06:51 AM
97civic_V-Turd
Jul 13, 2016 05:50 AM
lilredracer
Oct 26, 2005 06:42 PM
BoM
Jul 24, 2001 09:10 AM
