damn thing wont start
i got a 88 crx si with a sohc zc swap. u turn the key and noting happens! no slicks no sound no nothing. there is power and what not just aint turning over! what could be the problem
this just happened to me i checked everything from starter relay to starter first check to see if you can jump your car from the starter with a wire touching the remote wire and the hot wire if it starts i would def check your neg. battery ground see if it has a good connection and the wire isn't frilled that's what happend to mine.
GoldCoin
Jan 26, 2008 11:41 AM
