Aeromotive A1000 fuel pump installation
Old Apr 15, 2008 | 07:32 AM
b16b18's Avatar
Default Aeromotive A1000 fuel pump installation
An Aeromotive tech told me that this pump requires a -10AN feel line from the tank to the pump. I've been using -8AN. I still plan on running -8AN on the outlet but should I switch the inlet to -10AN? Am I starving the pump by having -8AN inlet feed? I'm having issue with this pump that I recently installed. I think the motor might have seized. Any of you with this pump, what size inlet line are you running?
Old Apr 15, 2008 | 07:40 AM
1992Si's Avatar
You should run the correct size inlet. People will tell you anything you want to hear.
The company making the pump knows best.
Also be careful with terminal post don't over tighten the nut's. Been there, done that.
Old Apr 15, 2008 | 05:31 PM
b16b18's Avatar
Default Re:
I will go with Aeromotive's advice to have a -10AN inlet. This is a popular pump so I was wondering what other people are doing in their setups.
Old Apr 15, 2008 | 05:49 PM
1992Si's Avatar
Ours had a -12 inlet, and that's what we fed it with.
Old Apr 15, 2008 | 07:42 PM
SPOOLINmatt's Avatar
Default Re: (rota92)
i run -10 feed and-8 main line
Old May 21, 2008 | 07:21 AM
AllMotr's Avatar
Default Re: (SPOOLINmatt)
i also run a -10 tank to pump and -8 pump to fuel rail.
Old May 21, 2008 | 07:41 AM
B18c1turboedEK's Avatar
Default Re: (AllMotr)
We run 8an for feed and return!
Old May 21, 2008 | 11:33 AM
Mikey3000's Avatar
Default Re: (B18c1turboedEK)
i run -10 from sump to pump and pump to rail. -6 return. i use the A1000 too.
turbo-crx
Feb 21, 2011 11:15 PM
paulzy
Jul 26, 2005 09:59 PM
Jared
Feb 1, 2004 05:27 PM
1 2 NV
Sep 4, 2002 12:44 PM
