boost on a stock LS
Old Apr 15, 2008 | 07:20 AM
iwanaturboteg's Avatar
Default boost on a stock LS
how much risk of damage is there if you were to run 5-8 psi on a completely stock B18A1. taking into consideration, the engine has high mileage and it burns a small amount of oil, but compression is good across the board and runs strong. with a proper tune would turbocharging it effect the reliability ??? all thoughts welcome thanks
Old Apr 15, 2008 | 07:30 AM
gsilnc's Avatar
do it
but id highly recommend some aftermarket internal components.
5-8 psi is good, personaly i would go past that.
Old Apr 15, 2008 | 08:55 AM
super jdm yo's Avatar
Default Re: (gsilnc)
5-8 psi is fine for stock. everyone i've seen that boosted their stock motor was rolling around with 6 psi. but since you say the motor has high mileage and burns a little oil. i worry that boosted it would speed up you motor to an early grave. i recommend a rebuild with some aftermarket parts.
Old Apr 15, 2008 | 09:07 AM
91redteg's Avatar
Default Re: (super jdm yo)
if yuv got a legit compression test id say yur fine i drive around every day with 12.5 lbs on a stock bottom end with plenty of boosted miles. especially 5-8 lbs that wont affect relaibility. it will get boring fast tho
Old Apr 15, 2008 | 09:10 AM
mnxxxEk's Avatar
Default Re: boost on a stock LS (iwanaturboteg)
Yea, from what I know boosting 8lbs on a stock motor is completely fine. Just make sure you have a boost gauge to make sure you're not over-boosting.
Old Apr 15, 2008 | 09:18 AM
TehGhett0P1mp's Avatar
PSI doesn't matter.. because its a useless number if we arent talking about the same turbo. Your HP goals will determine what will break and what wont. What are your goals? If done correctly turbocharging wont affect the life of your engine a whole lot but, if you slop **** togther it will be a diaster.
Either way go to the FI forum and read some more info.
Old Apr 15, 2008 | 09:34 AM
Default Re: boost on a stock LS (TehGhett0P1mp)
this makes sense im looking to get around 200-225. i dont need much more, sense its a daily driver. i stumbled onto a really!!! good deal on the turbo kit so im trying to weigh the benifits of putting it on... what about the greedy e-manage... this came with the kit. how well is this piggy back system. is it universal between differnt honda engines???? i appricate all the help
Old Apr 15, 2008 | 09:36 AM
Rickdrizzle's Avatar
Check out the f/i forum. The gurus there will shine the light for you.
Old Apr 15, 2008 | 09:42 AM
91redteg's Avatar
emanage blows. chrome is cheap these days and it squats all over emanage.
Old Apr 15, 2008 | 09:43 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iwanaturboteg &raquo;</TD></TR><TR><TD CLASS="quote">this makes sense im looking to get around 200-225. i dont need much more, sense its a daily driver. i stumbled onto a really!!! good deal on the turbo kit so im trying to weigh the benifits of putting it on... what about the greedy e-manage... this came with the kit. how well is this piggy back system. is it universal between differnt honda engines???? i appricate all the help </TD></TR></TABLE>
Dont use a FMU their garbage, at the least get your ecu chipped and use chrome its free and you wont blow your **** up using a shitty fmu
Old Apr 15, 2008 | 10:00 AM
thanks for the advice i will remember that. i only ask because i have one that was apart of this greddy turbo kit.... and i spent 300 bucks total on the kit...
Old Apr 15, 2008 | 10:07 AM
95teg_ls's Avatar
b18a? so is this in a da? if you you dont have an obd2 and cant run the emanage anyways
Old Apr 15, 2008 | 12:48 PM
NAmodified's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TehGhett0P1mp &raquo;</TD></TR><TR><TD CLASS="quote">
Dont use a FMU their garbage, at the least get your ecu chipped and use chrome its free and you wont blow your **** up using a shitty fmu</TD></TR></TABLE>
for ur 411. FMU are helpful when your car requires it. If you car is completely built then yea a fmu will help out. if you have a few bolt ons, dont expect much.
my car is tunned on chrome
Old Apr 15, 2008 | 12:49 PM
IanB's Avatar
Default Re: boost on a stock LS (95teg_ls)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95teg_ls &raquo;</TD></TR><TR><TD CLASS="quote">b18a? so is this in a da? if you you dont have an obd2 and cant run the emanage anyways</TD></TR></TABLE>
Not true, my only experience with tuning Greddy E-manage is in a boosted '93 Corolla, it is OBD1.
Old Apr 16, 2008 | 10:36 AM
95teg_ls's Avatar
Default Re: boost on a stock LS (IanB)
i thought the greddy only worked on obd1s, on their website it says their kits are for 96-99 integras
Old Apr 16, 2008 | 10:46 AM
DrGrEeNtHuMb's Avatar
SO HE CAN PUT ON A BEGINNER TURBO KIT (IM ASSUMING THE BEST) , AND RUN IT AT 22PSI ON THE STOCK BLOCK AND WILL LAST FOREVER AS LONG AS HE HAS A MANAGEMENT SYSTEM? I DONT THINK SO.
GET A NEW SET OF PISTONS AND RINGS AND THEN IT WOULD BE **** AT 12PSI ALL DAY. NOW IF YOU DONT WANT TO DO THAT AND YOU THINK YOUR COMPRESSION IS FINE, RUN IT AT AROUND 8-10PSI. ITS BEEN PROVEN AND PROVEN AGAIN TO RUN GREAT AS A DD G/L
Old Apr 16, 2008 | 11:52 AM
1990 crx dx b's Avatar
Default Re: boost on a stock LS (DrGrEeNtHuMb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DrGrEeNtHuMb &raquo;</TD></TR><TR><TD CLASS="quote">SO HE CAN PUT ON A BEGINNER TURBO KIT (IM ASSUMING THE BEST) , AND RUN IT AT 22PSI ON THE STOCK BLOCK AND WILL LAST FOREVER AS LONG AS HE HAS A MANAGEMENT SYSTEM? I DONT THINK SO.
GET A NEW SET OF PISTONS AND RINGS AND THEN IT WOULD BE **** AT 12PSI ALL DAY. NOW IF YOU DONT WANT TO DO THAT AND YOU THINK YOUR COMPRESSION IS FINE, RUN IT AT AROUND 8-10PSI. ITS BEEN PROVEN AND PROVEN AGAIN TO RUN GREAT AS A DD G/L</TD></TR></TABLE>
Don't be an idiot. Everyone knows you don't measure your **** by just psi. 7-8PSI on a GT30 is different than on a TD04HL or a T3/T4 or whatever turbo it is.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NAmodified &raquo;</TD></TR><TR><TD CLASS="quote">
my car is tunned on chrome </TD></TR></TABLE>
FMU = garbage after 5psi without a tune.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rickdrizzle &raquo;</TD></TR><TR><TD CLASS="quote">Check out the f/i forum. The gurus there will shine the light for you. </TD></TR></TABLE>
Homemadeturbo.com
Old Apr 16, 2008 | 02:23 PM
Schister66's Avatar
Man U FTW
If you have a question on turbocharging your stock LS, i suggest checking out the Forced Induction forum, but reading the FAQ before posting anything. In the forums other than FI, you end up getting a lot of misinformation and ignorant posts that aren't going to help you achieve your goals.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1990 crx dx b &raquo;</TD></TR><TR><TD CLASS="quote">
Don't be an idiot. Everyone knows you don't measure your **** by just psi. 7-8PSI on a GT30 is different than on a TD04HL or a T3/T4 or whatever turbo it is. </TD></TR></TABLE>
x2
89civicsiB18B
May 14, 2005 07:56 AM
hatchyboy89
Dec 16, 2004 06:22 PM
ScorpioX
Sep 23, 2004 11:20 AM
DeL SLo
Jan 11, 2003 11:43 AM
bisket
Dec 5, 2002 04:27 AM
