Car shuts off while stopping..
Old Apr 14, 2008 | 10:04 PM
91EF_Si's Avatar
Default Car shuts off while stopping..
I have a 91 hatch with a 97 ls running obd1. In cold mornings, it has a rough start but gets normal once warm. Major problem i'm having is, once in a while when im braking to stop...car either drops idle to 200-400 or shuts off. Starts right back up but once it starts, it keeps going. Any ideas?
I've changed the PCV valve, cleaned the IACV, and adjusted the idle.
Old Apr 14, 2008 | 10:15 PM
meCka's Avatar
Do u have problems starting it back up when it shuts off?
Modified by meCka at 12:19 AM 4/15/2008
Old Apr 14, 2008 | 10:31 PM
91EF_Si's Avatar
Default Re: (meCka)
No, starts right up.
Old Apr 14, 2008 | 11:19 PM
meCka's Avatar
any CEL?
Old Apr 15, 2008 | 06:33 AM
91EF_Si's Avatar
Default Re: (meCka)
Yes, CEL 10 TPS. But it throws it once in a while. And CEL 41 o2 sensor, wich is not wired up.
Old Apr 15, 2008 | 11:30 AM
Tim2179's Avatar
eight equals equals equals D
Community Builder
Loved
Default Re: Car shuts off while stopping.. (91EF_Si)
Is you neg battery wire secured?
Had a similar problem - my car would sputter and sometimes stop when I hit my brakes or stopped (bc my battery wire was popping off) and then when it stopped, it would start right up (since my the wire would then slide back on). Probably not the cause of your problem, but worth a shot.
Old Apr 15, 2008 | 03:27 PM
Blahblah718293's Avatar
Default Re: Car shuts off while stopping.. (Tim2179)
tps could be it, just check all the wiring, jiggle it around, you know. also: im assuming its a 5 speed, right?
RuskeR
Jan 22, 2008 01:53 PM
jmpgraphy
Dec 30, 2007 09:39 PM
blu3g
Sep 11, 2006 02:51 PM
q.man06
Feb 25, 2006 07:54 PM
ranta18
Jan 29, 2005 07:43 PM
