Draft: 17x7 OZ Superleggera Silver 4x114.3 with tires
Helping a buddy of mine to get rid of his wheels.
17x7 OZ Supperleggra in Silver
bolt patter 4x114.3 with a offfset of 40+. The center bore is 76mm
There is no type of curbed on the wheel they are all straight checked on a Tire balancer...I would rate them at 9/10 just because they are used
Tires that are on them are
2 Kumho Escta AST 205/45/17 H rated has tread depth of 9/32 less than 4k miles before he took them off the car
2 Yokohama AVS ES100 z rated has 6/32 tread depth. these have slight camber wear to them and are slightly cup on the inside.
They came off his G20 then had them on his Accord....I beleave they will fit the 240sx with a 4 lug also but you will have to find out...will fit others with the same boltpattern so do your research before asking if they will fit my car or not....as i do not know that answer...
PM If you have any question Topy
Located in Nashville, Tn can be pick up or will ship at your exspense by FedEx
H.
Apr 15, 2007 12:23 AM
17oz, 17x7, 2000, 4x114, 4x1143, 76mm, bore, civic, oz, sale, superleggera, superleggeras, supperlegera, ultraleggera, wheels
