Suspension & Brakes Theory, alignment, spring rates....
suspension ?'s
Old Apr 14, 2008 | 07:52 PM
slammedda9's Avatar
Default suspension ?'s
Basically i'm looking for input on which suspension would suit my needs. Basically i want to have something thats semi comfortable being that it will be put on my dd. I also want to give the car a considerable drop (2.5"-3"). Would a tein basic coil over setup be the way to go? Bear in mind that i don't plan on taking my car to a track. I'm not looking for the tightest auto x suspension. I just want decent handling for around town, and something that will provide great ride quality--something that won't bottom out or slam over every bump, but will still provide a "slammed look". sorry if this sounds like a noob ?, i've searched and came up with some good info, but i want to hear some first hand input.
Old Apr 15, 2008 | 10:31 AM
98vsmhatch's Avatar
So what car do you have?
You cant have all the things you want, pick 1.....There is no such thing as a "slammed LOOK" its either Slammed or its not.
Old Apr 15, 2008 | 10:56 AM
meb58's Avatar
Default Re: (98vsmhatch)
Slammed doesn't = great ride quality. slammed implies too little suspension travel, high springs rates - to keep parts from crashing into one another, and strong damping rates to control the springs.
Megan??? you can lower the car - to a point - without affecting suspension stroke. There may be a few more manufactuers who design their kits with this type of adjustability. It is a great concept, but slamming is not...there are more than a few gemotric considerations to fight with when the ride height becomes too low. Then, I humbly submit, you are in the game for looks only...
Old Apr 15, 2008 | 03:10 PM
slikz714's Avatar
Default Re: (meb58)
if you got the money for the tein basic coils then go for it. they're chill for dd
Old Apr 15, 2008 | 06:40 PM
TOO MUCH TORQUE's Avatar
8k/6k springs from tein basics might be too bumpy for you. i had 10k/8k omnipowers and i removed them 3 days later and bought koni/gc because they were soooo stiff.
right now im at 6.4k/4.5k or 350/250 and its PERFECT! i love this setup so much, it is only slightly stiffer than stock when you have the dampening to full soft.
look into koni/gc. they go for about 800 and it comes with lifetime warranty
Old Apr 15, 2008 | 07:43 PM
slammedda9's Avatar
Default Re: (TOO MUCH TORQUE)
ok maybe slammed was the wrong choice of wording. first off the suspension will go on a dc2 chassis.
basically my question is which type of suspension would give me a comfortable ride quality as a daily driver if i were to drop the car say 2.5"-3".. because my tokico blue/ground control setup sure isn't doing the job.
again i'm prepared to be flamed. i'm a noob when it comes to suspension. im just researching my options and becoming more familiar with what is out there.
Old Apr 15, 2008 | 07:47 PM
slammedda9's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TOO MUCH TORQUE &raquo;</TD></TR><TR><TD CLASS="quote">8k/6k springs from tein basics might be too bumpy for you. i had 10k/8k omnipowers and i removed them 3 days later and bought koni/gc because they were soooo stiff.
look into koni/gc. they go for about 800 and it comes with lifetime warranty</TD></TR></TABLE>
how much of a drop are you sitting on with your koni/gc setup?
Old Apr 15, 2008 | 08:13 PM
Default Re: (slammedda9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slammedda9 &raquo;</TD></TR><TR><TD CLASS="quote">
how much of a drop are you sitting on with your koni/gc setup?</TD></TR></TABLE>
http://www.flickr.com/photos/8447487@N07/page2/
click pictures of the white integra, click ALL SIZES, right above the picture for a bigger picture.. that is my drop and i believe its close to 2.5 inches.
btw, have never bottomed out.
Old Apr 16, 2008 | 04:37 AM
meb58's Avatar
A 3" drop is huge!!! You cannot obtain that goal without running into geometry problems. I'll second the GC kit, it is a great kit if setup properly. It is inexpensive, designed well, easy to install. The rates described by slikz714 are the rates we used on my son's 99 Si.
I used 400# front and 600# rear with custom valaved double adjustable Konis when I owned the car. The suspension is completely new at this point, completely!
also, if you have a double wishboe car, a 3" drop may allow the upper control arms to slam into the shock towers.
Old Apr 28, 2008 | 12:56 PM
slammedda9's Avatar
btw, have never bottomed out.</TD></TR></TABLE>
perfect.. thats exactly what i was looking for..
hondapeeler
Suspension & Brakes
19
Dec 16, 2010 01:24 PM
Nicks95GSR
Apr 12, 2007 09:52 PM
Lewy. Dee Ayy
Apr 29, 2006 03:17 PM
Rob Dizzle
11
Dec 18, 2001 05:41 PM
