JUST COP A GSR. vtec issue.
let me make things less complicatedd..
1. hit vtec on the highway
2.check engine light went on
3. code read- p1259 VTEC System Malfunction fuel air metering
4. anybody went thru the same problem? if do please help.
5. what the worse case can happen.
6. thank you very much for your opinion.
ps. vtec still kick in
Modified by teggy_617 at 4:53 PM 4/15/2008
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teggy_617 »</TD></TR><TR><TD CLASS="quote">i just brought a 96 gsr. so one of these day on the highway i hit vtec. and suddenly my check engine light wentt on. and afta that i feel like im laggin as in when i press on tha gas it wont let me shoot out quick, buh afta 3000 rpm or so it normal. it like something holding me back before that. like im pressing on tha gas pedal hard buh it not moving like it suppose to be? bogs? would that b the word ? i dunno. neways so i put a scanner and it real. p1259 fuel air metering. that what it say. buh i do some research online it say something vtec some shizz. can someone please help me so that my gsr can be where it supppose to beeee.. thankkkk youuu</TD></TR></TABLE>
First of all it didnt say something vtec some shizz it said P1259 VTEC System Malfunction... Which means you could have a pretty serious problem get a helms manual and go through the troubleshooting for that code..
It says probable causes could be the VTEC solenoid valve, open or short in VTEC solenoid, Valve circuit, VTEC pressure switch, open or short in VTEC pressure switch circuit, ECM
Try resetting your ECM... unplug your BACK UP (7.5A) fuse from the under-hood fuse/relay box for 10 seconds
Also so you dont get flamed and so people can understand you and help you a little easier write a little more clearly
honestly i don't really understand...i kno u want some sort of comment so i'm leaving one...cars and racing is an expensive sport...it seems like everything will be expensive...as for ur issue? u say it struggles between 0 and 3000 rpms? maybe its your throttle body? intake? idk...i'm sorry i can't really help but at least i'm responding
I dont think anything bad will happen, as in irrepairable damage but basically the vtec wont engage and you'll be loosing power and your car probably wont rev past about 7k
google search hondahookup manuals you can find information in there about how to test the electronics and fix whats wrong
vtec not engage? buh my vtec is still kickingg in tho.. hMmm. thank you steveo135 for ya opinion tho. really appreciate it. hopefully my problem be solve soon hehe.
