Hey guys I need a little help......
Old Apr 14, 2008 | 06:08 PM
Quade's Avatar
Default Hey guys I need a little help......
So I have one of those early type JDM H22A prelude vtec (1991) engines with the con rods that say PT3 on them. Using Slhondaparts.com what should my part number be for the con rod bearings? The bearings should carry holes in them which line up with the hole in the rod. I ordered a complete set using part number 13025-P14-800 and on the invoice it clearly shows that this item was removed and replaced with part number 13214-P30-004. These bearings do not carry the holes in them. Was looking forward to my build this weekend. Did I order the correct bearing by part number?
Basically need to know what's the part number for the con rod bearings with the holes for the JDM H22A. I understand that this hole provides a little more lubrication on the thrust side of the cylinder wall and would like to maintain this feature.
Modified by Quade at 3:14 AM 4/15/2008
Old Apr 15, 2008 | 02:36 AM
Quade's Avatar
Default Re: Hey guys I need a little help...... (Quade)
bump for the correct part number. Did they send me the incorrect part?
Old Apr 16, 2008 | 10:21 AM
Quade's Avatar
help......
Old Apr 16, 2008 | 10:29 AM
mgags7's Avatar
why not just drill the holes yourself, they have the slot right?
Old Apr 16, 2008 | 01:31 PM
Quade's Avatar
Default Re: (mgags7)
No slots. These are connecting rod bearings not main bearings.
Old Apr 17, 2008 | 02:51 AM
Quade's Avatar
Default Re: (Quade)
Any H23 guys out there that did a rebuild?
Old Apr 17, 2008 | 04:22 AM
PirateMcFred's Avatar
I do not know what the P30 rod bearing is cross referenced to but you can use any 1990-1997 Accord rod bearing in any 95mm cranked engine. Call the local stealership and ask what car the new part number is associated with.
Also I don't think that the oil hole is that crucial H22's don't have them and neither do B-series. So if the bearing fits then run it I say.
Pirate
LovinVTEC4
Jun 13, 2007 04:21 PM
ron-j
May 26, 2007 04:23 PM
B18C5-EH2
Sep 10, 2003 07:59 AM
HybriDNA
Jan 1, 2003 11:15 AM
