Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
CRX snap oversteer how do you setup for RR?
Old Apr 14, 2008 | 06:02 PM
Suzukii's Avatar
Default CRX snap oversteer how do you setup for RR?
Hi guys,
I've researched this forum and most setups are running harder rear spring rates to increase rotation on the crx. However, our experience on road racing is the CRX has a very loose tail and snap oversteer is very severe. Granted driving style is very important, ie no mid corner throttle lift, but due to the short wheel base, the rear is simply too loose for high speed corner entry. The car is so twitchy, its very unstable on fast tracks.
I would like to know what setups are you running for fast flowing road race circuits?
I think a rear GT wing is essential for the crx to increase more rear end grip and perhaps a stiffer front sway bar to reduce oversteer.
Old Apr 14, 2008 | 06:17 PM
blue_shtuff's Avatar
Default Re: CRX snap oversteer how do you setup for RR? (Suzukii)
do you corner balance the car?
Old Apr 14, 2008 | 06:19 PM
Suzukii's Avatar
Default Re: CRX snap oversteer how do you setup for RR? (blue_shtuff)
yes, car is corner weighted.
I'm now planning to build a GT wing to get some downforce and keep the rear more stable.
What LSD choice do you guys run? 1.5way or 2way?
Old Apr 14, 2008 | 06:37 PM
MightyMouseTech's Avatar
What kind of alignment settings are you running? What kind of tire size/pressure/compound? There is more going on here than just spring rates.
Old Apr 14, 2008 | 06:38 PM
Chris F's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suzukii &raquo;</TD></TR><TR><TD CLASS="quote">yes, car is corner weighted.
What LSD choice do you guys run? 1.5way or 2way? </TD></TR></TABLE>
1.5-way on a FWD car.
I can't answer for the CRX guys but you *can* race successfully without a wing. SCCA ITA CRX's are plenty fast without them and some Honda Challenge H4 cars don't use them either.
Soften the rear until you're comfortable. There's no point driving a "theoretically fast" car if you don't have any faith in it doing what you want it to.
Where is it twitchy? Fast corners, slow corners, corner entry, corner exit? Do you trailbrake?
Old Apr 15, 2008 | 05:40 AM
GI8U2racing's Avatar
Default Re: CRX snap oversteer how do you setup for RR? (Chris F)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suzukii &raquo;</TD></TR><TR><TD CLASS="quote">our experience on road racing is the CRX has a very loose tail and snap oversteer is very severe. Granted driving style is very important, ie no mid corner throttle lift, but due to the short wheel base, the rear is simply too loose for high speed corner entry. The car is so twitchy, its very unstable on fast tracks.</TD></TR></TABLE>
First off, have you replaced your TORN rear trailing arm bushings? If not, there's your problem
Yes, they are a little less forgiving than other cars, sure. But it is barely noticeable, especially if you drive consistently. You have 3 obvious options, pick one:
1. Add more front sway bar/Loosen rear sway bar
2. Increase front spring rates/lower rear spring rates
3. Loosen rear shocks/stiffen front shocks
I'm sorry, but don't come here with generalizations that a car is naturally tail-happy. Drive a stock CRX and tell me they are snappy! I feel my car is super easy and fast to drive. If I lift halfway through a turn, sure, I'm spinning, but it's not rocket science to keep your foot on the fast pedal
Old Apr 15, 2008 | 07:56 AM
Suzukii's Avatar
Default Re: CRX snap oversteer how do you setup for RR? (GI8U2racing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GI8U2racing &raquo;</TD></TR><TR><TD CLASS="quote">
I'm sorry, but don't come here with generalizations that a car is naturally tail-happy. Drive a stock CRX and tell me they are snappy! I feel my car is super easy and fast to drive. If I lift halfway through a turn, sure, I'm spinning, but it's not rocket science to keep your foot on the fast pedal </TD></TR></TABLE>
Thanks, will try your recommendations on the next track day.
Old Apr 15, 2008 | 08:09 AM
Good luck to you, let us know what ends up fixing it for you. Also, make sure your tire pressures are even when hot. Only start the rears 2-4 psi above the fronts when cold.
Old Apr 15, 2008 | 08:21 AM
essex's Avatar
The crx is tail happy and it does snap oversteer in comparison with a civic or integra, this has been posted 1 trillion times in this forum form guys with experience for the past baziilion years. No need to be giving people the hammer for asking a legit question.
Old Apr 15, 2008 | 08:42 AM
essex's Avatar
Default Re: CRX snap oversteer how do you setup for RR? (essex)
For Suzukii
if you go to search
then type
crx oversteer or crx tail happy or or crx loose
check "archived" content
select the road race forum
then check "search in post bodies"
then next
theres quite a few results ....even GI8U2racing's topic lol
Old Apr 15, 2008 | 06:52 PM
tom91ita's Avatar
Banned
some crx's are snap happy because the after market rear bar is binding.
make sure it is free. it is typically the set-up and it may not be what you think it is.
Old Apr 16, 2008 | 12:17 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by essex &raquo;</TD></TR><TR><TD CLASS="quote">theres quite a few results ....even GI8U2racing's topic lol </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GI8U2racing &raquo;</TD></TR><TR><TD CLASS="quote">First off, have you replaced your TORN rear trailing arm bushings? If not, there's your problem</TD></TR></TABLE>
That was the problem with mine and many others
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by essex &raquo;</TD></TR><TR><TD CLASS="quote">No need to be giving people the hammer for asking a legit question. </TD></TR></TABLE>
Hey hey, I was giving the hammer for just remembering to keep your foot on the fast pedal, it should be natural...
fireant
May 10, 2011 04:25 PM
Suzukii
Dec 11, 2008 02:00 PM
ED9man
Suspension & Brakes
Dec 7, 2006 09:23 AM
Tyson
11
Sep 22, 2003 11:45 AM
*Boostwerks*
11
Mar 11, 2003 04:51 AM
