d15b7 into a 1990 two door hatchback
I was wondering if I could put a d15 from a 93 civic into a 1990 civic hatchback manual 4-speed tranny. What do I need for this swap. (shift linkages, ecu, wiring harness, etc) Any help would be appreciated. Thanks, David
yes you can. heres your list
original parts:
ecu
wire harness
axles
trans
intake manifold
exhaust manifold
distributor
waterpipe(on back of block)
mounts
basically your only going to use the long block(head and block only, unless converting to multi point) from that 93 civic
lmk if you need more details
original parts:
ecu
wire harness
axles
trans
intake manifold
exhaust manifold
distributor
mounts
i have a 91 civic hatch and i want to convert the intake manifold how hard is this and will this give me more horsepower cause the d15b2 feels like it takes forever to accelerate..and how do i do the conversion will it jst hook right up ..thanks
Thanks alot man this is gonna help me alot even though im not really familiar with wiring the wiring ill make it work ..is there any other advice you can give me to making more horspower ..thanks again ..
Smooth89Hatch
May 4, 2004 08:27 PM
